terrible belt squeal
Old 07-23-2014, 04:24 PM
tyler_zzz
tyler_zzz's Avatar
Default terrible belt squeal
belt squeals unbelievably loud at the start of the car and goes away completely about 10-15 seconds later but its extremely embarrassing. And if i turn on the AC it does not go away at all. What is wrong? what belt is it? does it need to be replaced or tightened or what? 05 350z with 75,000miles
Old 07-23-2014, 04:40 PM
mkiv20vt
mkiv20vt's Avatar
More than likely it needs to be tightened. My VQ used to do the same thing on starts. Tightened up the tensioner and all was well.
There is a DIY on how to adjust your belts in the DIY section. I would start there.
Old 07-23-2014, 05:56 PM
guitman32
guitman32's Avatar
Make sure not to over tighten the belts. You may have glazed your belt and I wouldn't want to see you compensate by over tightening. Probably its fine but just want to put the concept into your head. A new quality belt like a dayco or gator is worth its weight especially in those brutal WI winters.
Old 07-23-2014, 06:58 PM
labelworkshop75
labelworkshop75's Avatar
Tighten to fix squeal. Inspect. Replace if worn.
Old 07-24-2014, 01:19 PM
myfirstzcar
myfirstzcar's Avatar
Yup, a little loose.....Probably needs replacing anyway. It's super easy.
They have to be tighter than you think, but it's real easy to go too far.
If you have eyes on the end of your fingers you can do it from above.
3vilbunny
07-18-2017 05:10 PM
Vigman
11-17-2015 04:34 AM
Fixxxercask
11-09-2015 11:10 AM
samansharif
09-25-2015 12:31 PM
Quick Reply: terrible belt squeal
