A/C pressure Switch HELP!
on
Hey my car was involved in an accident a while back, and most it was fixed, but the wiring to the ac pressure switch was basically cut. Its three wires. Does anyway know were each wire goes to and the colors. Or possibly have a diagram. I tried searching but this isnt a common problem.
Year of car? Go here for the factory manual, find the section, it should have diagrams. ATC is the air cond section.
http://www.nicoclub.com/FSM/350Z/
From a quick look at a 2008, the refrig pressure sensor is a black/white wire to pin 1, white on pin 2, gray on pin 3. The sensor or connector should be labeled. http://www.nicoclub.com/FSM/350Z/cou...adster/ATC.pdf (pg 37 there, may be different if yours is not an 08)
If you still need it I can pull a wiring diagram tomorrow at work.
04-04-2016 07:52 AM
