cant get into 2nd gear feel like a "wall" blocking it - 05 350z
Hello, im going to keep this short and sweet.
05 35th ann model oe clutch and tranny - 118kms
all gears are fine except 2nd gear, when i start in first going at a moderate acceleration and i slowly shift into 2nd, it wont let me.... i feel like there is a "wall" blocking it into 2nd.... this problem is on and off, doesnt happen after i drive it for a while. and occurs also slowing down to turn when im in 3rd to 2nd the same problem happens... im thinking its a bad syncro?
any help would be great
thanks for your help. im going to call my local Nissan specialist to quote me a price, is there anything else i should get replaced while their working on that, other than clutch and flywheel?
what happens if you are accelerating hard and you try to shift?
Addition^
this blockage only occurs when i shift slowly in lower rpm's- 2-4k..... like in the morning drive, how u just shift very easy.... thats when it happens.... (car is warmed up too)
if the car is warm, and it's only happening in lower rpm i'm going with syncros.
apparently its prty expensive because they have to take apart the tranny etc........ f*** it i guess i can live with it.... thanks for the help anyways
its not "that" bad that i need a new tranny lol.......i wouldnt of bought the car if it did.
I will confuse you even more and say go with only GENUINE NISSAN MANUAL TRANSMISSION fluid. That should be the first step and learn how to drive to get the synchros working for you. AKA rev matching on an upshift...Second is almost useless on our cars anyway. Go from 1 to 3rd
