VDC, Slip, Airbag, engine lights on
I recently did a wire tuck & now the VDC, Slip, Airbag & service engine lights are on. I relocated a few ground wires & extended some other wires for lighting. The only thing I extended that may throw a warning light was the airbag sensor in the front. Other extended wires were for headlights & one ground wire. ODB scanner is showing no codes. Car starts fine. Have not drove the car since I started it up and seen those lights. Any help.
did you disconnect the HVAC unit?
General & Tech Moderator
Return everything to it's previous state. Could be bad connection, wrong wire gauge, bad ground or bad solderless terminal.
How old is your battery?
