About to hit 80k, due for an oil change, should I start using 'High Mileage oil"
on
Hello, I've been using Mobil 1 Full Syn since I got my car with around 40k miles on it. They have a "High Mileage Oil" for cars with 75k+ miles. Is it a good idea to switch over to using this now, or continue using the standard Full Syn?
One of the main features of High Mileage Oils is a seal and gasket conditioner. If your Z doesn’t leak oil or burn oil. Just keep using what has been working for the time being. If your car doesn’t leak but has started to burn some oil, give the hi-mileage oil a try. If it is the valve seals responsible for the oil burning, this may fix it.
I wouldn't. When I worked at Napa I used to recommend using high mileage oil for cars over 150k miles. Anything under as long as you are not having issues I would recommend using regular oil. In your case full synthetic.
liqalu04
01-02-2022 12:58 PM
