Wrong Tires Fitted!
Old 11-12-2014, 07:14 AM
r3dg3cko rob
r3dg3cko rob's Avatar
Default Wrong Tires Fitted!
Hi Guys,
A couple weeks ago I had a flat on the way to work, so took it to the nearest Firestone to replace both fronts. Long story short; they put a larger tires on than needed 40/19s instead of 35/19s.
It caused the VDC OFF and Slip lights to come on - and the car wasn't starting correctly so after digging around on here I checked the tire sizes and last week took it back to the shop. They switched the tires for free (as they should) and the lights went off but I'm still having irregular issues starting the car.
If I understand the mechanics, the change in the rolling radius upset the speed sensor, causing the cam sensors to be out of whack, hence the lights coming on? Seems to make sense to me...
My question then is, should they have re-aligned / reset the cam sensors to fix the problem? I've checked the battery and the starter motor seems fine as when it does crank it's fine and healthy.
Rob
Old 11-12-2014, 08:57 AM
dkmura
General & DIY Moderator
dkmura's Avatar
Received 1,290 Likes on 894 Posts
Rob
You really don't understand the mechanics of the VDC system. There's NO connection between the wheel speed sensors and anything causing "the cam sensors to be out of whack". The problems you're having with starting the car is a completely different and separate issue than anything having to do with tire size.
Old 11-12-2014, 02:19 PM
r3dg3cko rob
OK I'm confused. So there is no correlation between the rolling radius of a tire and the speed sensor on the car?
It seems unlikely to me that the car goes into the garage for two tires, and comes out with warning lights on the dash and problems turning over without any of them being related. Especially when changing the tires back to the old rolling radius removed the waining lights? Guess it could all be coincidence though.
Could leaky cam sensor seals cause the issue starting? They need replacing apparently.
Only other thing that needs replacing that I'm aware of is the valve cover gasket as it's leaking but I can't see why that would cause intermittent ignition.
Old 11-12-2014, 02:33 PM
dcains
dcains's Avatar
Two separate issues. The word "coincidence" exists for a reason, and this is one of them.
Old 11-12-2014, 03:50 PM
r3dg3cko rob
OK, cool. I'm not disputing the fact it could be coincidence hence why I used the word.
My question again, is what could be causing the intermittent ignition issues. Battery check was fine. Spark plugs and coils are brand new. It's just not turning over one minute and then try it a few times or leave it a while and it starts perfectly.
Old 11-14-2014, 11:35 AM
Spike100
Spike100's Avatar
I suggest getting the code(s).
Old 11-14-2014, 11:50 AM
travlee
Master
travlee's Avatar
Received 9,044 Likes on 6,510 Posts
i agree with spike....
Old 11-18-2014, 09:07 AM
r3dg3cko rob
Only code I'm getting is in pending. random misfire cylinder 4. That could be the one that's leaky but could that cause it not to start?
Old 11-18-2014, 09:10 AM
travlee
Master
travlee's Avatar
it usually number 6 that gets the oil in it.... the coilpack could be going bad though
Old 11-18-2014, 02:41 PM
r3dg3cko rob
Just drove home from work and didn't get any codes this time. No pending or logged. It's getting harder to start though. It seems to be starting fine once the engine is warmed up though.
Old 11-18-2014, 04:22 PM
Spike100
Spike100's Avatar
How did you know that you "didn't get any codes?"
Questions:
1)When do you test for codes?
2)How do you test for codes?
Old 11-18-2014, 04:37 PM
r3dg3cko rob
I've got an odb2 Bluetooth tool that connects to my phone. I used the torque app to check while I was driving and after I stopped the engine.
Old 11-18-2014, 08:42 PM
terrasmak's Avatar
Received 2,283 Likes on 1,645 Posts
Explain more about the starting problem
Slow to crank
Cranks for 5 seconds before it fires
Etc etc
Obadabot
06-18-2023 11:31 PM
08-06-2021 06:19 AM
Quick Reply: Wrong Tires Fitted!
