2003 350Z Misfire
What ended up being your problem?
And my cars comcarnsy misfiring, so I don't think it would be a good idea to take it out and drive it while logging.
My OBDII does have a live can feature but I've only used it on idle, is there any info I can give you from there to help me out?
I assume that it should say "constantly misfiring" above? I answered you a couple of time quickly at work and I did miss a couple of details such as being able to drive it ,etc.
If you don't have cats, I guess you can run it safely at idle for some trouble shooting in the garage. But live readings are supposed to only be trusted after the car warms up (thermostat is 165-185 from what I can recall).
So,
1) literally a constant misfire or is it random? (mine sometimes only happened once a week on a daily driver) I would think a constant misfire will make this somewhat easier.
2) can you run the car safely long enough to warm it up then get all of the live readings possible with the scanner and post them here for us? That would be a great first step.
I listed my problem in my first post.
So,
So,
It doesn't go away and come back, it just misfires as soon as the car is turned on until I shut it off.
So I am guessing that you don't want to run it a lot. You could still start it up and tell us the live data anyway.
You said that you changed plugs and bought all new coil packs. I think that you said it misfired before and after you did this. But lets get the obvious problem out of the way first. Did you confuse the wiring harness for coil pack 4 and 6? This is the most common mistake in a plug change. I know it seems obvious but if you did make that mistake, you could have had a bad coil before the swap, then put in all new coils but wired them wrong and still have a misfire. Long shot but make sure you didn't do this first. You would not be the first person to do this.
I gave up on fixing it myself, waiting on some performance parts to come in the mail and I'm just going to have it towed to the mechanics to fix and install everything.
Will keep you guys updated on the fix tho!
Thanks for all the help
Justin100
11-29-2015 03:58 PM
