How to remove door panel?
Old 12-10-2014, 04:07 PM
cntrysamm
cntrysamm's Avatar
Default How to remove door panel?
eh, just decided to take off door panel to replace window motor. Didn't see any bolts to remove panel. How would I go bouts doing this? Pls let me know.
Thanks
Old 12-10-2014, 05:15 PM
CJM
CJM's Avatar
Searched "350z Window Motor Replacement" in google and got this:
https://my350z.com/forum/maintenance...dow-motor.html
It's the DIY I used. Should help you
Old 12-10-2014, 08:13 PM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,255 Likes on 2,316 Posts
Thanks
The only bolts to remove are located under the pull handle (pry out the back cover) and behind the window/door control panel. Pop out using a panel removal tool, starting at the back.
Rest of the panel is held on with nylon retaining "rivets" which pop out when you use the prying tool around the bottom and rear edge of the panel.
You will need to disconnect the door lock and door pull cables from the latch to completely remove the panel.
Hope that helps.
EDIT: Wise idea to have extra "rivets" mentioned above. I bought a thousand of 'em (well, maybe 25 in a bag) to have on hand when I ripped apart all the panels in the car to do the speakers/amp. Once they break (and they do), they're useless tossaways.
Old 12-11-2014, 01:29 PM
cntrysamm
cntrysamm's Avatar
Going to attack on the weekend thanks man
Old 11-11-2015, 04:40 AM
Bill_350Zzzz
Bill_350Zzzz's Avatar
Default Door panel removal
This video should help you. I had to replace my window motor in the passenger side.
3vilbunny
07-18-2017 05:10 PM
Gruppe-S
Body Interior
13
05-16-2016 10:42 PM
Depravity
10-01-2015 04:49 PM
Quick Reply: How to remove door panel?
