Changed spark plug and found OIL!
Old 12-15-2014, 02:19 AM
Qslank
Qslank's Avatar
Default Changed spark plug and found OIL!
Hey guys I have a 2004 350z just did The spark plugs and found some oil in the passenger side of engine last plug, took out the coil packet and cleaned that off and replaced the plug and asked my neighbor who's a crew chief in airforce and he said its probably a valve cover gasket and I'll need to replace it. So now a hundred miles after spark plug change got a low oil pressure light when in first gear slowly moving with clutch halfway released to just creep along.. But when idling was fine. So checked my oil level and was pretty low on oil, guessing it's from burning it up so went oht bought a quart put it in and is running and idling fine also bought new valve cover gaskets while at the store.
Just wanted to get some other opinions on this topic, any one else had this problem before? If so let me know if appreciate it
Old 12-15-2014, 03:53 AM
travlee
Master
travlee's Avatar
Received 9,044 Likes on 6,510 Posts
nope never heard of it, kinda like you never heard of searching
https://my350z.com/forum/maintenance...acement-2.html
https://my350z.com/forum/maintenance...ug-well-2.html
Old 12-15-2014, 04:30 PM
tommy smith
tommy smith's Avatar
Default I didn't have to search far or long
Originally Posted by travlee
A wise guy, aren't you ???? I'm sure there are many, many more.
Not much different than I am.
Old 12-15-2014, 04:35 PM
travlee
Master
travlee's Avatar
tis better to be a smart *** than a dumb ***........ just sayin
Old 12-15-2014, 04:40 PM
tommy smith
Default I said a wise guy
You said a smart ***. I remember that you posted often, but nothing stands out
Old 12-15-2014, 10:34 PM
Wietse350Z
Wietse350Z's Avatar
I was looking for the same story some time ago for my Infiniti FX35, 4 out of 6 show some oil in the plug hole.
This will not be solved by buying a new cover gasket, inside the valve cover are 3 custom O-rings around each sparkplug hole.
These are a fixed part of the plastic valve cover and are *not* replaceable.
I've read the story of drilling out the OEM valve covers and install some aftermarket seals etc. but with all the respect, i don't think it's reliable.
A set of new OEM valve covers is the way to go.
Does yours leak that bad from the one plug hole that your oil level drops that fast?
Old 12-16-2014, 03:31 AM
travlee
Master
travlee's Avatar
maybe he doesnt have the money to buy new ones
Old 12-19-2014, 07:02 PM
Qslank
Qslank's Avatar
thanks for your opinion, some very useful info you've put in this thread no wonder under your name says "master" lmao.
Old 12-19-2014, 07:09 PM
AdvanZ33
Senior Super Moderator
AdvanZ33's Avatar
Don't get too impressed, the "baiter" is silent
Old 12-19-2014, 07:10 PM
Qslank
Qslank's Avatar
Thanks I'm having my mechanic do it for me actually, unfourtanetly no time to do it myself but I'll let him know what you just told me!
Old 12-20-2014, 04:29 AM
travlee
Master
travlee's Avatar
me!?!?!?!?! and i see what you did there advan
Old 12-20-2014, 08:11 PM
bealljk
bealljk's Avatar
Received 1,282 Likes on 1,007 Posts
I dont think your problem is your valve cover seals but the fact that youre losing quarts of oil...how many miles on the car? did the '04 have problems burning oil??
Old 12-20-2014, 08:56 PM
billydabiller
billydabiller's Avatar
it's the seal around the spark plug. There was one place that was selling the seals don't know if they still do. You have to drill out the old ones and replace the new ones. They were selling rebuilt valve covers. I have the same problem with my 2004 I just take that coil out once in a while clean it and put it back on I don't have a problem with it. Sounds like what your talking about with the light is your running low on oil maybe you might be burning it. The dip stick on these is a pain in the *** to read and a poor design.
Old 12-20-2014, 09:36 PM
FOOKhonda
FOOKhonda's Avatar
I agree with the post above ^^^
And the dipstick is terrible, first time I did an oil change I apparently didn't get it all the way in and it spit out a bit of oil, which smoked forever when it got hot. It's in a terrible location, under the intake? Like really? They could've done much better but oh well..
Old 12-21-2014, 02:12 AM
Wietse350Z
Wietse350Z's Avatar
I hate this on my FX35, but the Z is HR engine and i was really happy when i opened the hood the first time and found the dip stick on a better location.
Old 01-10-2015, 10:12 AM
Qslank
Qslank's Avatar
Sorry for late reply but found out my piston rings are worn and probably my valve guides are worn out too so I either have the choice of a new engine or re manufactured engine or a overhaul on my engine that I have in there now
07-10-2022 07:44 AM
08-06-2021 06:19 AM
04-22-2021 09:42 PM
350z82
10-01-2015 06:25 PM
Quick Reply: Changed spark plug and found OIL!
