Replacing Headgasket while Block in the car?
Alright, Im putting cams in my Z but I have an extra set of heads separate from the ones in the car that have been ported/polished. My Question is, would it be possible to pull the heads with the block in the car? Hos anybody done this? and if they have did you just unbolt the headers at the header to cat/tp flange or did you have to unbolt them from the head? Would it be possible to remove the heads with the headers and maneuver it all out? thanks In advance
Better man than me...
Kyle - if/when you replace your headgaskets, give your new gaskets a few light coatings of that copper spray on both sides before you bolt everything back together. Not sure if this is standard knowledge or not...
http://www.permatex.com/products-2/p...sealant-detail
^question or statement?
I hung them and sprayed them and let them dry ... I wanna say I sprayed them 4 times...
The copper spray works good but a properly installed and torqued head gasket will seal anyway. The main use of the copper is to seal up small imperfections primarily on exhaust gaskets, on a head gasket if there are small imperfections it will fail, every time. The sealing surface needs to be perfect, there's just too much pressure and load.
lolwatbro
10-09-2021 04:58 AM
Vigman
11-17-2015 04:34 AM
350Z Project X
10-17-2015 05:16 PM
