Locating a wire harness connector
on
So my wiring harness going to my oil sending unit and oil pressure/temp has been chewed off by some animal.
I am having a hard time locating what this harness actually is and where I can potentially get some replacement connectors if the harness is too much of a pain to route.
The dealer was not really helpful at all; I would have to bring my car in..
2007 350z Enthusiast, AT.
Any help would be useful. Thanks!
Your best bet will be either ebay or find a salvaged z locally off craigslist and snipe the harness off a donor car...splice it into your wires.
I would double check your wires before you splice everything together.
hatersgonnahate
i definitely have an oil pressure sensor clip for you.
how much wire do you want left on it?
Also if your willing to depin your connector (easy to do) I can just send you wire terminals for less. Solder those back in line and then put your existing connector back. This only works if your connector is not mangled.
on
Hey sorry.
If you can just cut them with 6-8" leads. Can you take pictures of them and possibly give me what the number on them is. I want to make sure they match up. My connectors have been fixed but I am trying to find replacements for future issues because we had to splice right at the connector.
Here is pictures.
Here is pictures.
hatersgonnahate
The one of the left is your oil pressure sender. The one on the right looks aftermarket as maybe a temp sensor?
they dont generally have numbers on them. I know exactly what connector is for the Oil pressure sensor and traced it back through the harness. Ill provide a pic.
Can you get a better pic of the two wire on the right.
Tochigi_236
09-27-2015 03:40 PM
