VDC & SLIP Light on
on
VDC & SLIP Light on
Two weeks ago my 04 enthusiast started up just fine and after driving 15 minutes on the highway the engine lost power for 3 seconds (RPMs wouldn't go up or down when I pushed in on the gas) and then I regained power and both my VDC and SLIP light came on. I took the next exit and turned my car off, waited 5 minutes hoping the lights wouldn't be on. When I did it took about 4 seconds to start and the lights still remained on. I got home and waited 3 hours to try again and it started up just fine???? Now this keeps happening every time I drive for about 10-15 minutes. Can someone please chime in!
Is your steering wheel straight? Do you need or have you recently had an alignment? How about the battery? Has it been disconnected recently for any reason? Symptoms sound like your steering angle sensor needs to be recalibrated.
on
I also replaced my battery about 4 months and had it checked already.
on
Check fuse #15.
on
Sure enough it was my camshaft position sensors, I replaced the straight passengers side and the angled drivers side. Only took about an hour for both and I've driven the car hard with no problems
That explains the P0340, but none of those other codes would be set by a cam sensor. They must have been past codes that were never cleared. Fuse 15 is for the O2 sensors and wouldn't have caused all of those other codes. It must have been removed or replaced at some point.
^^ Ahhh yes... the infamous and notorious O2 sensor codes...
I've owned and serviced my 350z for 12 years now. Over the years I've learned how to interpret the code readout. Sometimes a combination of codes leads you to a solution.
