My Z wont start someone HELP!!
So I was working on the Z yesterday, and unplugged the MAF sensor (forgot to unplug the neg terminal for the battery). I had my friend start the car, and it wouldn't start. It would keep on cranking but wont catch. I plugged in the MAF, and unplugged and plugged back the neg terminal. Car still wont start. When turning the car to the on position, the fuel doesn't prime. The check engine light doesn't blink anymore like it used to. I think some other lights are missing too. The fans also turn on, as soon as I turn the car to the on position. I think the ECU isn't connecting to the car, because I tried to do the ecu reset, and that didn't work (no check engine light) so I left the neg terminal unplugged for 18 hrs and that didn't do anything. Tried jumping the car, wouldn't help. What should I check from here. I did a lot of research and no one ever posts the solution to the problem. I am going to the junkyard tomorrow to get some parts, and fusible links, maybe that would get the car running. Someone please help, any help would be GREATLY APPRECIATED!!
I thought my MAF sensor was put the wrong way, due to having not very good throttle response, checked it, and it wasn't. So I decided maybe if I started the car, I could see if the MAF affected the car in some way, which I couldn't tell if it was or wasn't because after trying that, the car wouldn't start.
sadly im in the same situation as you, my car wont start. Do you have any friends with a nice mechanic-type computer? not a simple ebay OBD2 reader. that would give you a better idea of the ECM being good or bad(if that computer connects to the ECM, then its ok and functioning... if not well it probably need either replacement or fixing). my car wont give any signal through the OBD2 port, giving the idea it needs replacement... which im working on.
by the way check your ignition coils, especially the ones closer to the back(i think the cylinder numer 5 and 6 ), do they appear burnt? like a little bump on the opposite site of the connector?
Good thing we met on here with the same problem! I checked one of my coils it appears good! I don't think it really has to do something thru the engine. And I really don't recommend replacing the computer unless you know for a fact is the computer. I have a friend with an expensive OBD ll reader (is that what you were referring to as mechanic type computer?), I'll try to borrow his to make sure, but I think I already know that my ecu isn't connecting, because my CEL isn't blinking as it should when you have the car on. I think you should check your fuses and switch out your ECU relay with your headlight relay and see if it starts. I don't think the ecu is bad for either of our cars(due to it being a very similar problem). I don't think its the ecu because I replaced my ecu with an ecu from an 04 and CEL still wouldn't show up on the dashboard. I know that the CEL is supposed to come on because I own this 04 ecu (had it lying around), and I remember that when I used to connect the ecu, I would get a CEL blinking (even when the car is just on and not started). BTW I originally can't start my car with this ecu, because it hasn't been programmed with my car/keys/other parts. Do you have anything else I should check for? And do you think that it might be a fusible link?
yes for mechanic type computer i refer to something like a snap-on. I already switched my relays and checked every fuse, and sadly it would not work. Mine seem to short something out and burnt those 2 coils and made the ECM unresponsive (BTW previous owner of my car seems to have deleted the CEL, thats why i always use the OBD2 reader). But for the test you made with your extra ECM, I think you might have a loose ground(that would prevent the circuit from being "complete" and thus your ECM not giving signals of life), checked those?
oh my car burnt an ignition coil... replaced that. weeks later burnt another ignition coil(all while driving) on the second time the car stopped starting... it just cranks.
That's great news, at least your car works now. Well as far as throttle response I have very little to no idea on why might cause that, but as usual inspection for that I would look at spark plugs, the MAF sensor(which you already did), and the throttle itself. If I'm not mistaken I have heard of this throttle to give problems after cleaning them, and that one of the solutions for some of its problems its the relearn procedure from nissan itself. other than that I'm out of ideas. BTW was the fuse that gave you problems the IGN & ECCS CONT fuse?
General & Tech Moderator
