Help no power to A/C compressor
on
So the blower is working but it's damn hot. Took it to Firestone to have the full Evac and re charge since I just did a motor swap. It's the same vq35de motor. Firestone tested the connector going to the compressor and he said I have no power. I replaced the AC compressor relay in the IPDM. No luck... Putting it back together, I found a connector on the front end that I couldn't find its home. Not sure if that has anything to do with it.
on
Okay so after running through a list of what it could be, came to the pressure sensor. And the lack of one at that. I put a new condenser on and forgot to switch over the connector on top of the bottle. I know I know I'm stupid. Oh well. But I'm about to swap the sensor on and hopefully it works.
on
Fixed it
Okay so I actually put the pressure sensor on the condenser. Went to advanced and bought a do it yourself for like 35 bucks. If you saw, I previously wasted 140 at Firestone for them doing it. Anyways, the second I pulled the trigger with the A/C pro, the compressor kicked on. Not even halfway in, the AC was pretty cold. By the time I was done, it was way too cold and I'm in 90-100 degree weather. So 35 bucks to charge the system and keep in mind, the system was filling discharged. Well worth the money and like 3 minutes to do it yourself.
