Cylinder 2 MisFire & Knock Sensor
on
About a week ago, I was sitting at a stoplight when all of the sudden my Z's idle gets rough, sputtery, and shaky. I accelerated from the stoplight with noticeably reduced power. I drove it to AutoZone and got "Misfire Cylinder 2" and "Knock Sensor" error codes.
The next day, I was able to successfully replace the knock sensor, but it did not fix the issue. I drove it back to Autozone, they cleared the codes, and I received the same two error codes.
What am I missing here? Has anyone dealt with this or can anyone provide advice?
(I can hear a high pitched clicking noise about two times per second under the hood, may or may not be related.)
Can we all assume that you havent performed any modifications or alteration that would prompt a misfire / detonation?
I hate blaming things on bad gas but you may want to drive your car at a light load for as long as you can and then fill up at a different station. You could also dump one of those 'octane in a bottle' bottles into this fuel to see if it stabilizes things.
on
Yea it's all stock except rims and suspension, nothing that would cause a misfire. I seemed to rule out bad gas because I filled up and drove about 3/4 of the tank and the problem started at 1/4 tank.
Test the coil pack before you replace it. Swap it out with a pack from a different bank and see if the problem follows.
11-09-2020 10:27 AM
