What ECU code is being thrown here (vid)?
on
1 Post
I recording an ECU code being thrown, but cannot figure out what code it is -- and I have read ECU codes from my 350Z before.
Turn down the audio if my counting messes you up. It appears to blick 7 times and then 1 last quick blink for 8 in total. It does not seem to could off 4 digits as usual.
Any ideas?
(P.S. I have run into odd codes before, earlier this year and recorded them, if you are interested.)
Any ideas?
on
1 Post
pr_350z,
Thank you.
After all of this I agree. I have run into problems reading codes before:
https://my350z.com/forum/maintenance...es-videos.html
Perhaps the odd blinking is due to it throwing more than one code.
Plus, I had no idea OBD2 scanners could be as cheap as $8. I was thinking $100 or more. If you have any suggestions on a scanner, I would be pleased to know.
Thank you.
a lot of people use the free Torque app for android phones or tablets. I use a bluetooth version of an elm327, but careful, the first i bought did not connect with nissan vehicles. so ordered a different version and it worked. If you own an iphone you will need a Wifi version of an obd2 scanner as thats how they connect as far as i know. the obd2 scanner that worked for me looked like this http://www.ebay.com/itm/Vgate-ELM327-Bluetooth-OBD2-Car-Diagnostics-Scanner-Scan-Tool-Android-PC-v1-2-/331487969830?hash=item4d2e390226
on
1 Post
Thanks everyone.
Update on the code. It was a "P0455 EVAP system gross leak", which is likely a gas cap leak. The ECU should have blinked out the 0, 4, 5, 5 digits to me. No ideas why it did not.
11-09-2020 10:27 AM
