Flickering HID headlamp - what is cause?
All bulbs on there are sold in two. Also no point in replacing one.
But yes I went for that 4300 bs for a couple years and was sadly proven wrong by my eyes and plenty others on HIDPLANET when we went with a higher k rating. I wouldn't go above 5500 though
If it shuts off if you hit a bump Or go over rough lanes the it's the bulbs had the same issue went the wrong way by buying the ballest first bc the bulb looked fine when powered uped then finally got me some used oem bulbs off my friend for a test run and never went off hope this helps
on
HID flickers 2x then turns off (FIXED)!
I started off with replacing the ballast with oem ones from eBay but the lights would still flicker off. Ended up ordering morimoto bulbs and fixed my issue
dvlad
09-15-2002 07:48 PM
