Car Shakes When Idle?
Old 10-06-2015, 04:34 PM
DeeCryme
DeeCryme's Avatar
Default Car Shakes When Idle?
I have a 2003 Nissan 350Z with 131,000 miles on it. The car shakes noticeable when idle. I do have a service engine light that I checked out at Pepboys. The two codes that were given stated that I had to change the 1 spark plug & get a new ECM. Once I change both of these will the car stop shaking when idle? I changed the oil and gave it a light clean up today but it till shakes noticeable when idle. Any help or suggestions would be appreciated.
Old 10-06-2015, 04:38 PM
Emski
Emski's Avatar
If it's an automatic, there is a high chance it's the motor mounts.
DeeCryme (10-07-2015)
Old 10-06-2015, 05:01 PM
DeeCryme
DeeCryme's Avatar
Sorry forgot to state that. Yes it i a automatic. Should I replace the motor mounts? And how much will that cost?
Old 10-06-2015, 06:07 PM
hulkout
hulkout's Avatar
I would fix the misfire first. That can cause a shake. A new set of plugs is probably in order at that many miles. And I guess a new ecu if that's what you think it needs.
Old 10-06-2015, 09:10 PM
Surfer90291
Surfer90291's Avatar
Mine was stumbling at idle before starting to run like **** and it turned out to be misfire due to a bad coil. Check em.
Old 10-07-2015, 07:14 AM
hulkout
hulkout's Avatar
Check the plugs. If they look bad change them. If they look ok then what you can do is swap the cylinder 1 coil with another cylinder. Clear the codes so the CEL light goes off. Go for a drive. I'm assuming the code you got was a cyl 1 misfire code P0301. If the CEL comes back on and the code jumps to the cylinder you swapped the #1 coil to then you know it's that coil and you can replace it.
P0300 is random/multiple cylinder misfire
P0301 is cylinder 1 misfire
P0302 is cylinder 2 misfire
P0303 is cylinder 3 misfire
And so on.
Here is how the cylinders are numbered.
I don't know what to tell you about the "bad ECU" code. What was the code number?
Old 10-07-2015, 03:33 PM
DeeCryme
DeeCryme's Avatar
And so on.
Thanks for the detailed post, the codes were
PO302 - spark plug/bad coil
U1000 - ecm/ecu change needed
I took my car to a mechanic & he said its a bad coil & the second code he brought up was a transmission code. He said from just looking at it some sort of liquid might of feel into the gear shifter. He said that might be a possibility or something a lot worse. He said not to drive the car in Manuel.
He said he will change the coil plus full tune up for 400-500. He will also check on the transmission issue and let me know if its anything more serious.
i don't know if its a good deal or not. The car is a 2003 Nissan 350z Touring with 131,000 miles bought at 5,000 cash. Right now because I have to spend money to get things fixed I feel like I got suckered in the deal. but they said I paid a good price because everything else seems to be working fine. Until he gives it a real check up sometime in a day or 2. So Im just waiting on the verdict & the bill...smh. I love the car but I hope I didn't lose out in this deal. What do you guys think?
I also made another thread with a more detailed post & info.
https://my350z.com/forum/maintenance...l#post10661704
Thanks guys for actually taking the time to reply. And not flaming. New driver first car I'm learning as i go...
Old 10-07-2015, 07:47 PM
hulkout
hulkout's Avatar
The 0302 might cause the u1000. It's kind of a stab in the dark, but I have seen cases (mainly in fords) where, in simple terms for the sake of quick explanation, the plugs or coils have gone bad and gone unnoticed for so long that a signal back feeds into the ecu and fries it.
Also there is a tsb on our cars for u1000
http://engine-codes.com/uploads/nissan/NTB06-009a.pdf
Edit: the u1000 code is NOT the transmission code the mechanic pulled. That is a separate issue. The scanner that pep boys used would have only pulled ECM codes and not transmission, abs, or air bag codes. The scanner any mechanic worth his salt would use would be an expensive piece of equipment that could do all of that and more.
DeeCryme (10-08-2015)
04-04-2016 07:52 AM
Pengu
Motorcycles for Sale
01-04-2016 04:50 AM
Pengu
11-18-2015 02:57 PM
J R K
10-29-2015 06:34 AM
Quick Reply: Car Shakes When Idle?
