Driver side seat is stuck, how do I move it forward?
Hey all,
My electric seat is stuck and wont move forward. So I cant remove the seat and Im rather uncomfortable when i drive.
Is there a way to "jump" the seat to get it to move forward? Im sure its the switch thats bad since it goes back fine, just wont go forward.
I wish I had manual seats.
Mine did this once before, it eventually just started working again though.
You can jump the switch apparently, not sure how but someone recommended it.
You can also try cleaning all of the connections and see if that helps.
I know I'm not that much help.
I wished I'd bought a Track model instead of the Touring when this happened, I cleaned everything and haven't had a problem since though.
Can't clean it anymore since the seat is stuck in reverse!
its a simple electric motor, if going one direction works, you can just pull the plug and cross the wires and then when you push the switch forward, it will go backwards instead.
ukraini9mofo
11-05-2015 06:28 AM
