camshaft position sensor replacement.
I have replaced both bank 1 &2 camshaft position sensors but the car still died in the middle of an intersection. TCS and slip light came back on. I was going have my codes read again today at autozone to see if showing the same thing like maybe i got bad sensors from them. But has anyone else experienced this issue?
Master
did you replace with OEM sensors or ones from vatozone? when it comes to sensors, i try to stick to oem. where in TX are you?
after looking at your pic, guessing you are in the dfw metroplex (the phone number on the van). i would order them from courtesyparts.com, and pick them up will call at courtesy nissan off of 75
https://www.courtesyparts.com/nissan...amshaft-sensor
on
General & DIY Moderator
While the parts stores won't erase the codes, use the manual method. With the key in the ignition, quickly turn it to the accessory mode (dash lights on-no ignition) and back to off, six times in a row. The seventh time, just start your Z and see if a CEL appears once again. This method usually erases all ECM, BCM and ABS codes in memory.
Bizspeed
South East
11-19-2015 10:18 PM
aredd2009
11-19-2015 01:25 PM
Extreme Dimensions
Southern California
11-17-2015 01:24 PM
