Where is the heater blower fan relay located?
Old 11-26-2015, 10:31 AM
bazguitarman
bazguitarman's Avatar
Default Where is the heater blower fan relay located?
I'm pretty sure I need to replace my heater blower fan relay. My heater fan is intermittent. It exhibits the typical symptoms of a bad relay. I already have a new relay.
Where exactly is the heater blower fan relay located?
Old 12-01-2015, 03:29 PM
zakmartin
zakmartin's Avatar
FSM
And next time you post an issue question, at least include the year of your vehicle. The Z went through a major re-design in 2007.
Old 06-16-2017, 02:36 PM
shovonb
shovonb's Avatar
Originally Posted by zakmartin
FSM
I would greatly appreciate it if some one post a pic of the location the relay is located
Old 06-19-2017, 01:34 AM
beezee
beezee's Avatar
The problem is most likely the white ac/heater control box located under the radio. You have to remove the shifter surround to gain access to it
Old 08-30-2018, 03:06 PM
shovonb
shovonb's Avatar
It's right behind the fuse box.. so when you look right next to the dead pedal.. there should be a flap that you can open.. just open it and you'll see whole bunch of fuse and sht.. the relay is located right behind that box.. I know it sounds crazy but trust me it's there.. somehow get that b**ch out and look behind it you'll see two blue relay change both out.. one is for blower fan and another one for something else but its hard to tell which one is which but they are both the same.. so yeah replace them both and you should be good to go!
Old 08-30-2018, 04:39 PM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,253 Likes on 2,314 Posts
You are aware that you don’t need to repeat the answer three times..... google or site search will find the answer once for anyone looking for the answer that took a year to find. 😜
Just razzin’ ya but really....
AJLUVHERZ
01-26-2016 05:01 PM
MikeBit
11-26-2015 11:39 AM
DAgrizzly2
11-12-2015 10:10 AM
Bak3rme
11-08-2015 06:04 PM
Quick Reply: Where is the heater blower fan relay located?
