Trunk release button and keyless entry remote
Old 02-06-2016, 03:12 PM
tjc6591
tjc6591's Avatar
Default Trunk release button and keyless entry remote
My key fob has always been crappy, have to be right there on top the car to unlock it, and the trunk is always iffy on opening.
My key fob recently stopped working completely out of the blue, tried replacing battery and reprogramming it and still no luck.
I noticed as soon as the key fob goes out, the trunk release button above the plate doesn't work either. So I have no access to the trunk and am stuck unlocking car thru door.
Has anyone had this issue, maybe something like a sensor or something gone bad to pick up the key fob ?
Any help appreciated
Old 02-06-2016, 03:15 PM
PP08HR
PP08HR's Avatar
Trunk release will still work, you must have an additional problem.
Also that little hanging tab under the rear strut bar is a release.
Old 02-06-2016, 03:20 PM
tjc6591
tjc6591's Avatar
I have a custom box stuck in there blocking the emergency release.
Just found it odd to both stop at the same time.
Old 02-06-2016, 05:34 PM
jv350z
jv350z's Avatar
does the license plate bulb still illuminate? if not, then the culprit is the connector inside the rear bumper cover
Old 02-06-2016, 06:05 PM
tjc6591
tjc6591's Avatar
Ima check it in a few, I'll come back with an answer, and if it is, is it a harness or something needs changing?
Old 02-07-2016, 05:14 PM
jv350z
jv350z's Avatar
I would guess just the harness connector not properly snapped-in. did you have any work done in that area?
Old 02-07-2016, 06:11 PM
tjc6591
tjc6591's Avatar
Nah, no work done near there. The plate light doesn't work either tho. Guessing I'll have to take my bumper off and check the wires soon.
What about the key fobs, should I bite the bullet and buy a new one or do you think it's something other than just the fob ?
Old 05-06-2021, 11:20 AM
Tattoo1960
Tattoo1960's Avatar
im having a similar problem my remote entry stopped working can’t lock or unlock doors and set alarm, I replaced the battery but still no fix, my windows were opened a little the other day and it rained inside so I’m wondering what it did to cause this does anyone have any suggestions
atf07
09-07-2017 06:43 PM
psytropic
02-11-2016 01:18 PM
confusa
02-08-2016 01:10 PM
openupitsdave
02-08-2016 12:26 PM
Quick Reply: Trunk release button and keyless entry remote
