Fluctuating Idle
Fluctuating Idle
Hey guys, my idle is fluctuating between 1500 and 2 k rpm. I read thru a couple of the threads on here and still can't seem to figure it out. At first my mechanic said his scanner was showing the throttle body code so I ordered 2 used and he changed those out, code went and and yet the problem remained. Not sure what else to do, I am thinking maybe somehow my tune went bad? I left the car and went on vacation during the cold season then when I came back i noticed this issue. It actually started a bit of rough idle before the trip but not this bad. Mechanic tried the relearn using his scan tool and also tried to do it manually. Any suggestions? car is a 2007 tuned 350z hr with oversized intakes and big injectors
UPDATE
Just providing you all with an update. I am still having this issue, I have had the car checked out by multiple mechanics. All have no idea what is going on. I actually went to a Nissan dealership and had them do a diagnostic test on the car and they have no idea what is the exact problem. They suggested that I buy brand new throttle bodies from them totally $2200. They are not even sure this will correct the issue. However they did say they saw a misfire code in their scanner from a few cycles ago.
Today I took the car to a popular shop in the Miami area. He tried and failed saying he doesn't believe its a mechanical issue. I am thinking maybe my an injector went bad casing the fluctuating idle and the miss fire found in the history. I am thinking of going to my tuner to see if he can possible use uprev to control the idle. That is my last hope I have no idea what else to do. If this fails I might sell the car and get a daily to drive around before picking up a new toy in a few months. Any suggestions?
UPDATE
General & Tech Moderator
Grab a vacuum guage, hook it onto intake plenum. I'll buy you a pint if it's not a vacuum leak. Post up when you find the problem!
The_Assassin (03-23-2016)
Thanks for the response, he actually did check for vacuum leaks but I didn't see him use a special gauge or anything. You think its best to try this and not take it to the tuner? I already wasted money on throttle bodies that I am not even sure was the issue. Hopefully I can resell If I find out they are in working condition.
It does sound like you have a lot of moving parts. With an inexpensive gauge, this is an easy point to rule in/out. gl
A smoke test will reveal pretty much any leak. Most halfway decent shops have an automotive smoke machine.
Anyone think that there could be a problem with my tune ?
Without seeing what the shop actually did during your tune, it's anyone's guess. That being said, if the problem surfaced right after they performed it, then odds are it'd be a good place to start.
No the problem started maybe 6 months or so after the tune. He did have a problem with injector scaling though. With the bigger intakes and injectors the car was idling horribly until he got it sorted out.
I had big plans for the car was eventually going to get a Boosted performance kit. I have dual 3.5 inch custom made intakes and some people on here also changed their injectors when they got theirs installed so I figured why not do it.
Thanks for the heads up on the throttle bodies. Yea I have an appointment with my tuner for next Saturday.
Just to provide some sort of closure to this issue. I was never able to fix my Z. I got rid of it a few months ago and picked up a c7 corvette 3LT Z51 performance. Will be posting that up in the other cars section soon.
