06 350z high engine temp
Ok, so this is an odd one. I went to drive my 06 Z from North Carolina to Yuma Arizona. About 2700 miles total. Half way through, one of my stock cooling fans failed. The engine temp was fine as long as I was either rolling at a decent speed, or in traffic if I turned off the A/C it was fine. Drove it around a couple weeks before I fixed it about a week ago with brand new Mishimoto aluminum shroud kit with dual Mishimoto fans. They both are working and pulling air PERFECTLY. From that point on, there seemed to be no issues, until today. Both fans are still kicking great, but now the temp starts to climb with the ac on in slow driving conditions. (I live on a military installation where the max speed is a total of 25 MPH). If I have the A/C off, it comes right back down with no problem. Heater works fine. I bled the cooling system, there is no major air in there. And as previously stated, it was fine until today after I fixed the fans. I also have low oil pressure at idle (Not turn on the light low, but light valve tap low. Probably the rear timing cover gasket). Don't know if that will cause any problems with temp out here. It's about 95 outside for reference.
350zbruh
09-28-2017 11:57 AM
