Need assistance ASAP! Tail lights not turning on
Old 06-26-2016, 08:53 AM
verXic
verXic's Avatar
Default Need assistance ASAP! Tail lights not turning on
So for a few day before this my right blinker was blinking really fast. But just yesterday my tail lights went out, and so did my license plate light. I checked the bulb and only the right side tail light was out and had some kind of burnt residue. I cannot check the voltage of the socket.
Brake lights work perfectly fine.
So I replaced the tail light bulb and it's still not working, need some help ASAP! I can't drive like this for long and I have work for the rest of this week.. :/
Old 06-26-2016, 11:14 AM
HRMoneyPit
HRMoneyPit's Avatar
What work have you done recently?
Old 06-26-2016, 12:47 PM
verXic
verXic's Avatar
Strut replacement, that's it. Front Driver.
Old 06-26-2016, 12:55 PM
HRMoneyPit
HRMoneyPit's Avatar
You check fuses?
Old 06-26-2016, 03:06 PM
verXic
verXic's Avatar
You check fuses?
Checked IPDM, and the one under steering wheel. Not a single one is burnt or broken.
Old 06-26-2016, 04:27 PM
tampa_joey
tampa_joey's Avatar
the fast blinker - was the actual light flashing faster?
or did you only notice that the dash indicator was flashing faster and no idea what the actual light was doing?
you also mention that the tail light bulb was out-but what about the turn signal bulb?
admittedly- i am no electrical engineer- but things that also come to mind to check are all wiring around both strut mounts and also around the places that the strut bar that crosses over the top of the engine mounts to- and any places that you might have placed a hand on to get leverage (all of these sorta places in the engine compartment) and dont forget to check any plug connections even close to those places for looseness due to being pushed/pulled upon inadvertently
Old 06-26-2016, 05:29 PM
verXic
verXic's Avatar
Yes the actual light was blinking faster,I found out that it was the front passenger blinker.
Old 06-26-2016, 05:34 PM
travlee
Master
travlee's Avatar
Received 9,047 Likes on 6,513 Posts
funny how basic trouble shooting alluded you .....
Old 06-26-2016, 05:48 PM
tampa_joey
tampa_joey's Avatar
ok- so the fast blink was solved- what of the tail lights/lic.plate light?
Old 06-26-2016, 05:55 PM
verXic
verXic's Avatar
Tail lights are still out.
Lic plate also...
Old 06-27-2016, 08:57 AM
rustyschopshop
rustyschopshop's Avatar
if those lights are out more than likely the fuse is blown. There are 3 fuse boxes in our z's. Of course you know of the one under the dash as you wrote of. There is also 2 near the battery under the hood. The one you need to access is a pain in the **** as far as fuse access. You will need to remove the battery cover trim and wiper cowl on the pass side. Pull up on the fuse box cover and you will see them. Good luck and hope it helps.
Old 06-27-2016, 09:00 AM
verXic
verXic's Avatar
I checked those and none of them are burnt out
Old 06-27-2016, 09:07 AM
rustyschopshop
You may want to pull the tail light fuse and see if you are getting power to the box. From what you are saying, it doesn't sound like it will be an easy fix. I would recommend tracing circuits with a multi meter.
taywan
South East Marketplace
05-18-2016 09:40 AM
Tanahara
05-11-2016 09:00 PM
soysauce21
05-08-2016 10:09 AM
Quick Reply: Need assistance ASAP! Tail lights not turning on
