P1084 Fixed
P1084 Fixed
Hello everyone, I decided to make an account because I finally solved this problem for myself and couldn't find any straight answers on here before.
Problem: P1084 Exhaust valve Timing Control Position sensor (bank 2)
This seems to me to be a REVUP specific problem considering the standard DE's don't have variable valve timing for the exhaust and the REVUP's were the first to get it.
MOVING ON:
my specific symptoms were:
idle was bumped up to 900-1100
SES light error code P1084 (I assume this solution would also work with P1078)
I'm somewhat relieved of the timing however as this started the day after my inspection.
here's the problem.
DE REVUP's have four cam sensors (two in each cylinder head at the back of the engine; exhaust and intake)
Part numbers:
23731-6J90B and is used for driver side exhaust and passenger side intake (straight sensor)
23731-AL61A and is used for driver side intake and passenger side exhaust (angled sensor)
I removed my driver side exhaust cam sensor (underneath the throttle body) and tested it with a multi meter than compared it to my passenger side intake sensor.
I also took the time to live view all data related to my camshafts through Cipher. Exhaust camshaft Adv, B2 was stuck at 38.0 degrees CA while exhaust camshaft Adv B1 was anywhere between 121-122 degrees CA on idle. B2 never moved from 38.0 even while driving or reving the engine.
Getting different results between the two sensors I swapped them in each others places (remember same part number) and my car wouldn't start due to the dead sensor now being on the passenger side intake.
Called up to nissan to make sure they had the part in stock and I was on my way. $154.66 later and a new OEM 23731-6J90B sensor was mine. I got back home and swapped it in and now everything is good again! No SES light and no more high idle!
I would recommend disconnecting your battery before removing these sensors. All you need is a 10mm socket and 15 minutes max of your time to remove and replace this sensor. You can follow along with other threads for more specifics on how to remove and replace cam sensors.
MOVING ON:
here's the problem.
Part numbers:
That is correct, part number 23731-6J90B is a straight sensor. It is the sensor that fits in the driver side exhaust and passenger side intake.
on
Great. Would that happen to be the one with the green connector on it on the drivers side? I accidentally replaced the angled sensor thinking it was the one related to the 1084... Which was a black connector.
Let me get back to you on that tomorrow for sure on the color of the connector, but if you're looking from on top of the engine towards the car, it's the sensor furthest on the right, it'll also be lower than the one you replaced due to the way the cylinder head (V)
Just find the one you replaced, and go a little further down and on the outside of the head.
on
Ok, could use some help here. 2006 350z 6MT
I had the P1078 Exhaust valve Timing Control Position sensor (bank 1) CEL come on.
After reading up, I replaced the angled 23731-AL61A passenger side exhaust using:
Duralast Camshaft Position Sensor - SU6480 (Autozone)
Reset the check engine light. Now I have intermittent misfires on all cylinders and no power. It seems to rev up higher in lower gears faster than normal, but I have no power at all. Misfires when I let off the gas a lot and a couple of times during rapid acceleration. No solid check engine light after 50 miles of use. Just blinks for the misfires.
Any ideas??
Any ideas??
350z P1084- exhaust valve timing control position sensor bank 2
Rev-up issue- In clutch car won't stall or move. that means completely dead clutch plate.
I got my engine light on at the same time my clutch was dead. Drove it for few days and the car stop moving and the clutch was completely gone.
Before i changed my clutch plate even though i knew i need to replace it, first what i did was diagnosed my engine light to get the code. I got P1084 - exhaust valve timing control position sensor bank 2.
350z has **** load of sensors, and i figured this engine light has to do with my clutch plate because i got the engine light on at the same time when my clutch plate gone.
Replaced my clutch plate and the engine light disappeared . Unplug the battery leave it for 5 minutes and see if the light comes back on. As far as i know it did not come back at all. If it comes back and if you get the same code as P1084- exhaust valve timing control position sensor bank 2. That means you need to replace your catalytic converter oem.
Simple fix and don't stress your self by thinking too much with this rev-up issue. Common sense. If your rpm revs higher till you hit the red light and its on your first gear and no movement that means your clutch plate is gone.
Clutch issue
-hesitate to start
-hesitation on acceleration
-Lost of horse-power
-Burning smell
-Sometime when you rev higher for few minutes and the car is not moving and your steering wheel get tighten
-bad in feul
-you can drive for few days till the clutch dies completely, thats when you know your car won't move at all because the clutch is dead.
Clutch issue
-hesitate to start
-Burning smell
-bad in feul
MOVING ON:
here's the problem.
Part numbers:
MOVING ON:
here's the problem.
Part numbers:
P1084 Code
Sorry to bring up an old thread but is your Z LHD or RHD? I have the same code (P1084) and my drivers side is the right side. Not the left like in the US, just to help me along the right direction
Cheers in advance
Cheers in advance
on
2 of each?
MOVING ON:
here's the problem.
Part numbers:
MOVING ON:
here's the problem.
Part numbers:
There is not a specific “driver side” or “passenger side” sensor. The part numbers are interchangeable for both driver side and passenger side of the engine.
PN: 23731-6J90B is driver side exhaust and passenger side intake. This is the straight sensor.
PN: 23731-AL61A is driver side intake and passenger side exhaust. This is the angled sensor.
driver side exhaust and passenger side intake are interchangeable because they are the same sensor and same part number. (Straight sensor)
driver side intake and passenger side exhaust are interchangeable because they are the same sensor and same part number. (Angled sensor)
if you were replacing all of the sensors in the car at once you would order:
QTY 2 of 23731-6J90B - straight sensor
QTY 2 of 23731-AL61A - angled sensor
