Spark plug grommets
Old 07-12-2016, 05:26 PM
Siciliang35
Siciliang35's Avatar
Default Spark plug grommets
I've contacted rnd with no response so I've decided to go another route. Question is where else can I get the sparkplug tube seals?
Old 07-15-2016, 10:21 AM
Siciliang35
Anyone know?
Old 07-15-2016, 10:26 AM
HRMoneyPit
HRMoneyPit's Avatar
Nissan
Then it comes with valve covers attached to them
Old 07-15-2016, 10:33 AM
Siciliang35
Originally Posted by HRMoneyPit
Nissan
Maybe you didn't understand something about my question. Read carefully.
Where can I get the valve cover gasket and grommet kits besides rnd. I can't speak for you but I have common sense. I already know a valve cover comes with grommets.
Old 07-15-2016, 10:45 AM
Siciliang35
I did a quick search and found this.
https://my350z.com/forum/maintenance-and-repair/584338-spark-plug-tube-seal-transplant.html
This guy claims an altima valve cover is 30 bucks and the seals are the same .Has anyone done this?
Old 07-15-2016, 08:54 PM
HRMoneyPit
HRMoneyPit's Avatar
You obviously don't have a sense of humor lol
Get the stick out your ***
Old 07-16-2016, 07:34 AM
Siciliang35
I got a sense of humor I just rather get a legit answer and get this done rather than play games online
Old 07-16-2016, 10:27 AM
HRMoneyPit
HRMoneyPit's Avatar
You didn't have any answers so I helped you.
Old 07-17-2016, 08:30 AM
soc_monki
soc_monki's Avatar
Maxima covers can be used, but need slight modification. Many people have tried to get just the grommets, with no luck.
Old 07-17-2016, 08:02 PM
Vitamin_B12
Vitamin_B12's Avatar
rockauto has them listed for the 350z but since they are officially non-servicable and you have to cut it up to even get to it, it may or may not fit*
*i was sold a cabin filter from rockauto for an '02 corolla that as it turns out doesn't have a servicable cabin air filter (actually starts and fits '03, gave to a friend)
anyway, there was someone on here who bought some (don't remember which member and what brand / where he purchased from, but easily found on google) and his didn't fit, and he ended up just putting sealant on and putting the originals back in
Old 07-18-2016, 09:39 AM
Angrybird
Angrybird's Avatar
I bought a set from Rockauto before I learned I can't do anything with them. Had to buy a new valve cover (also from Rockauto). Not sure what to do with the seals now...
Old 07-18-2016, 03:10 PM
Vitamin_B12
so you tried the rockauto ones and they didn't fit? or you didn't know you have to hole saw your valve cover to get to them?
Old 07-18-2016, 03:26 PM
HRMoneyPit
HRMoneyPit's Avatar
Just buy the covers and seals together. Then do it over in other 80k
Old 07-18-2016, 04:50 PM
Emski
Emski's Avatar
https://www.z1motorsports.com/cylind...ge-p-7167.html
This is what I'll be getting.
Old 08-09-2016, 10:56 AM
brohawk
brohawk's Avatar
Had the same issue w/ RnD as the OP so went w/ the Fel-Pro ES70691 seals. They fit absolutely fine. You have to use a hole saw and apply some rtv, same as RnD's, but a couple differences as well:
1) Use a 1 7/8" hole saw instead of a 2" and that includes a pilot bit. You can then make your own jig w/ a 3" piece of 7/8" diameter dowel, drilled down the middle. Apply a few rounds of tape over the dowel to beef it up to just under 1"--the inner diameter of the seals is exactly 1" but I found a 1" dowel didn't move freely enough. Then cut a 1/2 piece of plywood out w/ the hole saw, wood glue it to the dowel and you have a jig that'll keep your cuts centered.
2) Cut down to the metal washer of the old seal, then you can pull it out w/ some pliers. It doesn't look like it'll come out at first, but wiggle it back and forth w/ a flathead screwdriver and it'll eventually pop out. After it's out, you need to use the hole saw again to grind down the inner ridge as seen in the below pic. But don't grind it down flat. Leave about 1/8" of it remaining so it props up the new seals flush w/ the baffle--the Fel-Pros aren't quite as thick as the old seals. Coat the bottom and sides of the hole w/ rtv, pop 'em in and let dry completely.
http://s235.photobucket.com/user/bla..._0940.jpg.html
I did this job on 7/31. Pulled all 6 coils again yesterday and everything was still completely dry. Hope this info helps someone else.
Vitamin_B12 (08-11-2016)
Old 08-11-2016, 08:48 AM
Vitamin_B12
thanks for sharing
what made you go with ES70691? rockauto (cheapest), autozone, and advanceautoparts say that for the 350Z the one that fits is ES72481
(does it differ by year? i put in '03 cuz that's what i have)
Old 08-11-2016, 10:54 AM
brohawk
brohawk's Avatar
Apologies, I googled "350z valve cover spark plug seals" to reference the part here and for some reason ES70691 comes up 1st hit when google shopping (which is actually for Acura/Honda/Isuzu).
I actually DID use the ES72481. Picked them up at a local o'reilly's for $26. Wasn't worth the savings for me to wait for shipping w/ rockauto / drive across town to the nearest autozone, when I could p/u same day just down the street from me.
Year shouldn't matter w/ these, but I have an '03 as well so you know.
turboed350z
08-05-2016 02:21 AM
DreamZcometrue
07-25-2016 07:25 PM
35reilly
Tuning
07-08-2016 10:22 AM
Crusade350z
06-24-2016 10:54 PM
DACodeRed
06-23-2016 04:03 AM
Quick Reply: Spark plug grommets
