Flex a lite fans continue to stop working
on
I installed Flex a lite fans in my 350z in 2010. They worked perfectly until the summer of 2015 at which time the fuse started blowing out on a somewhat regular basis and the fans would not work. In January of 2016, I replaced the fans as they were not working at all and the car would overheat.
The new fans worked perfectly until last Wednesday at which time they stopped working and the engine began to overheat and the A/C would blow hot air. I made it home by making my way to the interstate and the engine cooled down to a normal level.
The fans are still under warranty so they will replace them. However, I am unsure if I want to continue on this path or install the OEM fans back in it or acquire another set of aftermarket fans. The car is located in Florida and is running a Stillen supercharger.
Any suggestions or advice would be appreciated.
