Help! Oem seat wont bolt in!
Old 08-31-2016, 10:56 PM
SharX59
SharX59's Avatar
Default Help! Oem seat wont bolt in!
Hey everyone,
As the title suggests, my OEM driver's side seat will not bolt back in. The culprit? Well, it seems that upon further inspection the nuts that are on the underside of the floor pan (which make it possible to bolt down the seats to the body) have fallen off inside. This makes installing the seat an impossibility.
My question is to you fine folks is how do I remedy this situation?
If I may be honest with you, this issue has me extremely frustrated.
Old 09-01-2016, 05:24 AM
dboyzalter
6 inch cawk is my fave!
dboyzalter's Avatar
Sooo you cant get to the under side to access the nuts? Post up a picture so we can visualize the problem...
Might need to make an access hole.
Old 09-01-2016, 10:43 AM
SharX59
SharX59's Avatar
After some searching I found this thread with a almost identical issue as me.
https://my350z.com/forum/maintenance...and-floor.html
Here he had to only re-weld new brackets/nuts. For me, I'd need to actually cut open the floor to retireve the old brackets/nuts.
Old 09-01-2016, 05:17 PM
nizmo_0385
nizmo_0385's Avatar
I may be off but cant you get high strength nuts and weld to washer and then to floor or are the oem nuts and bracket necessary id leave in the floor
Old 09-01-2016, 05:22 PM
Spike100
Spike100's Avatar
Replace the nuts and you're good.
Old 09-01-2016, 05:27 PM
SharX59
SharX59's Avatar
You could do that, but then the washer would add a slight increase in height (which I wouldn't like already having head clearance issues). Even if I were to do that, there is still the issue or fishing the broken nuts out. I don't think the mounting nuts are large enough to pull them through the existing hole. If that is indeed the case I may need to enlarge the holes by cutting into the floorpan.
Old 09-01-2016, 05:29 PM
SharX59
SharX59's Avatar
I'd love to but the nuts are on the underside of the floorpan. The only way to access them is to cut out the pan. I'd like to avoid that if at all possible, but it looks like I may have to.
Old 09-01-2016, 05:47 PM
dboyzalter
dboyzalter's Avatar
Ok thought about it and here is my idea... Cut a small rectangular access hole... Weld a bolt into a rectangular "washer" same size as your hole... Put in hole turn 90 degrees... Weld to floor pan... Have a stud for seat put bolt on top...
Old 09-01-2016, 06:06 PM
Z1NONLY
Z1NONLY's Avatar
I made the thread you linked.....
I was able to get to the nuts with a dental tool. If you need a temporary bandaid, hold the nut in place with a dental tool while applying a couple drops of glue to hold the nut in place long enough to *carefuly* start the bolt by hand.
The glue is just so that you can start threading the bolt onto the nut. After that, they hold each other together until you can do a real repair.
^^this is just a temporary "fix". Get it fixed properly ASAP.
Old 09-01-2016, 07:37 PM
SharX59
SharX59's Avatar
Thank you all for your replies I appreciate it. I relayed much of what you guys told me to a local shop here in SoCal called Specialty Z. It seems like they could do the job.
Old 09-10-2016, 02:48 AM
cincysilvias14
cincysilvias14's Avatar
kinda makes me not wanna switch out seats to aftermarket when the time comes
sag
04-27-2016 07:50 PM
NeVrO
03-20-2016 10:25 AM
belkmike
07-09-2002 04:18 AM
NUJOYZ
06-18-2002 08:16 AM
Quick Reply: Help! Oem seat wont bolt in!
