Motive Power Bleeder 0107 or 0117?
on
I am attempting to bleed my brakes not my clutch and I want to make sure that I get the correct version of this product. I have been searching and see different numbers still.
Can you guys please help me out on which one is for the brake master cylinder reservoir I do not want to buy this and then they pay another $20 for an adaptor.
Bonus if you have a cheap place where I can purchase it.
350Z/370Z Tech Moderator
Check EBay for vendors. I think I got mine from one of the hot rod houses a while back.... Jeg's? Summit? One of them.
I have the black label version with all the adapters, but this is the one you need for the Z:
https://www.motiveproducts.com/collections/import-power-bleeder-kits/products/copy-of-black-label-ford-japanese-and-korean-import-3-tab-adapter
Without this, bleeding the brakes is almost impossible. Be sure to keep an eye on the fluid levels while you're working or you're just going to force air through the lines.
It took me three times but I eventually bleed my brakes the old fashioned way
I definitely need this bleeder though
