Vdc slip lights on air bag cel no speedo or cruise control. Help!!!!!
Ok so I am going to give this a try, sorry for the long post but I want to give as much info as possible. I bought a car that has all of the issues listed above in the title. I have owned the car since April and have pulled out the emanage that was in it and went to Uprev. I have had it tuned and driven it since then with no issues other than no speedo and the other listed above. I have had it scanned at Autozone and the codes that came up are P0500, P1212, U1001, P1564. I also had it hooked up to a snap-on code reader and drove it hooked up and no speed was being recorded on any wheel.
I have searched for this problem for a while and talked to a few people with no solution. The code that is trouble is the U1001 from my understanding as its a communication error. I did find one post where a guy said he replaced the air control unit???? under the radio and it fixed the problem. I did notice that mine does function but my defroster light will not light when pushed but I do hear a click for it and the temp does not change when I go from 60 to 90 with the temp dial. The previous owner said the Ac was deleted so I am not sure if that affects the temp changing or not. I was also leaning towards the abs control unit as I have hurd that does sometimes fix the problem. When the car was on the snap-on scanner he could not connect to the abs to read the codes if any there as well. The speed sensors seem to be in good shape along with the one on the transmission. About the car:
It is a 03 track edition 6 speed that has twin turbos on it with all of the other goodies. I can elaborate if necessary. The tire size is front 245/35/19 and the rear is 275/35/19. All help is greatly appreciated. I am not the greatest at electrical problems but am willing to give it a try before paying someone a small fortune to fix it. Thanks Joe
JoeJoe,
Sorry to hear about your problems. As a first step in understanding what's wrong, I suggest you download a copy of the Service Manual for your car. See http://www.nicoclub.com/archives/nis...e-manuals.html and follow the links for your model year.
Let me take a stab at diagnosing your problems. It looks to me like you have two issues. The P1564 fault, air bag light and cruise control problem point to a bad clock spring behind the steering wheel. The steering wheel may have been removed and improperly reinstalled. In any case, the items in the steering wheel are not connected to the wiring harness in the car.
The other fault codes and warning lights point to a communication problem on the CAN bus that connects all your car's computers together. The speed signal on the bus from the VDC/TCS/ABS control unit to the unified meter and AC amp seems to be missing or corrupted. The CAN bus will not function properly if any of the units on the bus are disconnected. Since your heater/defroster appears to also be inop, I suspect the unified meter and AC amp is the culprit.
JoeJoe13 (10-10-2016)
JoeJoe,
Is the unified meter and AC amp all one unit? Does it sound like mine is misbehaving partially? Why does my speed signal go thru my Ac lol
The unified meter and AC amp is a single unit. It sits behind the heater controls. As to why Nissan designed the electrical system that way, only Nissan knows.
I was thinking it is that part. I was looking around and cant really find one but when I do they are like 150.00 dollars. Do you think that is my problem?
Update: I went out and disconnected the white Ac amp and started the car. The gas gauge and now RPM dont work. Would that indicate the Ac amplifier is working correctly? Or maybe partially working?
Yes. The speedometer, tach, coolant temperature and fuel gauges receive their signals through the unified meter and AC amp.
Ok thats what I thought. Could it be damaged that only half of the systems are working on it and the other half are not? I got the led to light for the rear defroster only by taking it apart and using my multimeter to light just the led. Could I have a semi bad Ac amp?
Finally, ask the previous owner just exactly what he did to "delete" the AC.
Angry Ale (11-19-2021)
Ok so I did the instrument check and everything moved to where it should have. I tried the Ac one and all 3 led's light up which means its good????? I then turned the dial to auto and the one light blinked for only 10 seconds and then the ac light never lit up. I then turned the dial a little more and then it blinked again and then finally ac light stayed on meaning I guess everything is good. I then switched it back to auto and then the ac light when on. I tried the whole process all over again and I couldnt get it to check again when I put it on auto. Any thoughts. I really appreciate the help. I am going to try and find the fuses for it tomorrow when there is light. Will one blown fuse still let it semi work or would it disable the whole system?
I contacted the previous owner and he said he just removed the pump and the lines. Would that be why my temp does not move and increase or decrease when changed from 60 to 90
I called them before and they were talking about doing the consult 2 scan and I described my problems to him over the phone and he said 60 dollars wither they find anything or not. It didnt seem like he was real concerned with my problems only my wallet. Would the uni/ac amp cause the temp issue as well?
Ok I suspected so. All of the functions such as the power to control how much air coming out and the ventilation function works perfect as well. It is only the heat and the rear defroster. I might starting looking for a new unit to replace it and start there.
Master
I do have a question, is their a self diagnosis tool for the abs unit to see if it is faulty. I was looking in the online service manual to see and I cant seem to locate it if it does exist.
Update: I was driving the car today. Went from shifting from second to third accelerated a little and the car died. It will crank now but will not start. I sounds like the pump is not starting. The fans are now on when the key is on. Any help would be greatly appreciated. Thank You
