Car will not hold idle when restarted
My 2003 350Z with VQ35DE engine will not hold idle after it runs for a bit and I do a restart. Note, if I push the gas pedal to the floor it will hold idle. I recently replaced my valve covers due to leaky spark plug tube seals. When I took off the throttle body as part of the valve cover job I did not unplug it. However, I did clean the throttle body which I probably should not have done. Also no SEL is on. The problem started after I completed the valve cover replacement job. Any assistance or advice is appreciated. This car has a 6 speed MT and has no aftermarket mods. Miles on the car 144,000.
Thanks,
Mark
Thanks,
Mark
Master
Thanks,
Mark
Thanks,
Mark
http://www.rockauto.com/en/catalog/n...ttle+body,6472
http://www.rockauto.com/en/moreinfo....431958&jsn=371
350zmark (01-05-2017)
Travlee,
I installed the new throttle body and did relearn peocedures. Car is running great. Thanks again or the advice. Also, thank you for the help with the window motor.
Mark
Mark
