Popped the Cams?
Old 02-04-2017, 09:46 AM
aj555
aj555's Avatar
Question Popped the Cams?
Changing out the water pump, doing it myself, and I did not turn the crank all the way, so at one point, both the tensioner side AND the water pump side were both loose. I pushed on one end and it shifted back to being tight. Happened on BOTH sides, different times.
Do you guys think I popped the tooth/cams?
I would like to avoid taking the cover off, but I could always be safe than sorry.
Would like to get some input.
Thanks,
Alex
Old 02-06-2017, 08:36 AM
eZg
eZg's Avatar
I guess you are talking about jumping a notch on timing chain??
I'm no gearhead, learning tho, but your title seems a little 'Off'.
good luck
Old 02-06-2017, 09:16 AM
aj555
aj555's Avatar
good luck
Hah, well played. I watched a video and the guy used the term "pop the cams" so thats what I was playing off of. Sorry.
If anyone else takes a look at this I resolved the nervous issue by taking out the plugs and cranking the motor a few times to see if any valves would hit the pistons. All clear.
