Need help code c1145 and c1146
So im confused on whats going on, i cut the orange wire going into the yaw sensor and wired it to a switch.
I went ahead and removed the switch and soldered the wires back together but the vdc and slip lights are staying on and throwing code c1145 and c1146.
i replaced the yaw sensor but no luck in fixing the issue.
if anyone can give me some insight that'd be great.
Michael Murch (01-30-2020)
Similar situation here
I have had a little button (interrupter switch) hidden in my ashtray for over a year now with no issues. It works to disable slip and vdc. It defaults back to normal when the car is turned off and restarted.
I just upgraded to a newer model radio and now I’m stuck in “drift mode” hahah
Not cool though. I need to understand how to fix this. My connections are tight. I tried bypassing the switch. I checked the vdc fuse. Also Checked brake fluid.
Whyyy now?
So slick
Popped the caps off and it looks like it’s not goin anywhere...
please help! any ideas? Will update if I find a solution.
Whyyy now?
So slick
This is on my 2005 05 g35 6MT manual sedan
Lowered on 350z springs. Coupe midpipe and driver seat.
