Rusty's Slow Build.
rustyschopshop (09-14-2016)
#83
6 inch cawk is my fave!
I felt no difference, I replaced mine because it was a rusty mess and the stock piece was the same price as the ultra racing one. If your oem one is in good shape it wouldn't be good investment, if your oem one is completely fu˘ked i would say its deff better looking and worth it.
gringott (09-14-2016)
#86
I have plans for alot more of the unseen eventually. But for now trying to decide which direction I will go to repare the out of spec valve lash. May just buy a low milage vq for the time being to swap in and keep this engine to build or swap as a core toward a built long block later. Only time and finances will tell.
#87
I get it - I've spent some time under my Z and the metal isn't looking good. If a structural part is failing, why not replace it with something cleaner and more durable than stock? I just wondered if it had any other effect is all. Can't normally see a lot of things that I replace. lol More room by the exhaust is a positive IMHO.
#88
Started back into my tear down today, intake manifold and valve covers off. Used a boroscope to check upper cylinders. Founds that something small had been bouncing around the #1 cylinder. Found something brass looking sticking to the bottom of the head. Will be pulling the exhaut mani thursday to check the valve guide and get ready for more tear down. Also gonna try to pull the small object out. ATM funds are low so i am gonna try to go as inexpensive as i can. I would like to hold off on a built long block for at least another year. Depending on what I find thursday and friday will definitely set what direction I will go. Fingers are crossed. Worst case senario atm will be to drop in a used low mile engine from salvage. I really don't want to go this way. Yet if I need to I will.
#89
Some very bad news.... last sunday I reinjured my back and am out of work. Car is gonna be on hold, as well as some of my smaller hobbies. Herniated 1 disc and have a 10mm tear in another. Currently awaiting an appointment with a surgeon to see what my options are. My wife an I are also debating wether to go through the VA or not. Don't really want to do it through the Va but not sure if we can afford to do it civilian side.
#90
Sucks to hear, hope you have a speedy recovery... Im writing this while doing my back exercises on the yoga ball, I have some back issues also, it's no fun when your most important machine goes down.
I visit the chiropractor regularly now it seems to help, and I do pathetic yoga ball back exercises every day... (also hopefully help)
Anyway hope your back doing what you like to do soon, and good luck if you go through the VA... About 10 years ago I got a colonoscopy through them, my nurse was a retired marine and looked like grizzly Adams, and they drugged me up so much I missed 2 days of work (and I thought sticking a little camera up my a$$ was going to be the worst part)
Last time I hurt my back I was out for 3 weeks, I watched lots of pirate's of the Caribbean, transformers, and x men. O and lots of my350z researching...
Best of luck
Best of luck
#92
Just had an appointment with a surgeon, actually have 3 herniated disc, 2 of which have tears. He wants to recommend a spinal fusion but due to my age he knows it will lead to even more surgeries. Have another appt coming 28th of November with a VA spinal surgeon. More than likely will be getting a spinal steroid shot. We shall see.
#93
Master
#95
350Z/370Z Tech Moderator
Had a back injury some years ago (yes, Z related... car versus red light running taxi cab...but could have been worse.... mighta been a speeding Uber driver without commercial insurance. ). I healed up relatively fast (well, at least relative to it being a back injury) and hoping for the same for you!
rustyschopshop (11-01-2016)
#96
Sry for the last update but they ended up needing to due a fusion on my neck. I knew there was issues with neck but not to the extent that they found. Ended up with a c5-c7 fusion just shy of 2 months ago, still in a C-collar atm. If everything goes well collar should come off at my docs visit next week. Already have much of the strength back in my hands in arms although loosing strength from not being able to do anything. Even some of the issues I have had in my legs seem to be better.
As far as the car, ordered BDE engine mounts and Tomei headers. Received the mounts yesterday and headers should come tomorrow. Was hoping to get an engine ordered by now but looks like I won't be able to afford the IPP stage 2 long block I was wanting to get. Figured I would at least replace these pieces when I swap out the engine if I am going cheap. Found a Japanese import engine with 60k miles for just under 2k usd shipped that I may go with.
Hopefully more updates will come sooner than they have.
#97
Glad you are in better health. I have had back problems, helicopter forced landing issue, finally unbearable, could have gone VA or Tricare [private doctors not Army hospital], still waiting for the VA to call me back [+10 years lol] but the private docs did an excellent job and I have had no side effects and things have gone well, although there is pain I have learned to deal with it without medications. I do not regret the surgery at all.
Best of luck with the build.
#99
Sorry i missed your post dboy... it is time for an update
Finally got another retro payment from the VA but they shorted me again so no engine yet but got a bunch of goods that i wanted to change anyway
inland empire aluminum foam filled driveshaft---- OE shaft joints were shot when i pulled it a few months ago
torque solutions trans mount
southbend stage 2 with quiet disc with aluminum flywheel
Cd00A tranny to replace the original old tired cd001
Still have from earlier in the year awaiting install when ready
Tomei v2 headers
BDE billet motor mounts
upgraded my tool box from a 26" craftsman to a 52" husky, been needing this upgrade for many years
Health update:
Neck is doing really well
Today i just got back from having my back surgery--- still very tender atm but very hopeful for the outcome.
Current plans on engine are to buy a jdm import with less than 60k miles at tax time since i don't think i will be able to afford the IPP stage 2 that i want. We shall see what comes in a few months.
Tomei v2 headers
Health update:
