You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Why dont more people do this? Seems to me that losing 22 pounds for $135 is the greatest dollar per pound mod ever. Maybe im just skeptical but there has to be a downside...
ooooppppsss I didnt read that right. So the stock batt weights 35.5 Lbs!! WOW thats kinda heavy.. I agree with jcr847 that would be good lightweight mod.. What about coldstarts? Battery life? Basicly like he said is there any downsides? Is it a better battery?? hummm time for some reserch on Batteries!!
Well, I just fabricated my own strap out of a 2" X 1/4 steel plate strap. I bent it using a hammer and vice to conform around the top of the battery. I also used some 3/8" wood, cut it to lay into the stock battery tray, painted it black and bolted it in the existing tray. I then drilled holes in the steel strap and bolted it to the tray and the existing loop that was used with the stock mounting strap. I put a thin layer of rubber on the inside of the steel strp to make sure the battery wasn't damaged. There's no way that thing is moving! I purchased one online for $69 plus $7 for the studs. This is the best mod for the buck as far as I'm concerned. For $76, 22lbs is a lot when you add it to all the other lightweight mods! I'll check which brand of battery I bought this afternoon.
Do any of you know if the lighweight battery is legal for SCCA stock class AutoX? I can't find any mention of them, and I'm guessing they are legal since it would be lame to have to find a replacement battery that exactly matches the stock weight. Anyone know for sure about this?
