suggestions on 17" rims for racing
on
What kind of racing are we talking?
For road racing, I wouldn't go cheap. It's not worth having one break and wreck your car. If you absolutely must go cheap, then stick with a steel wheel, not aluminum. Middle-of-the-road aluminum wheels from reputable manufacturers will get you a nice, strong wheel properly designed to reduce stress cracks from fatigue.
The Rays (OEM on track) are excellent track wheels, except for the 18" size. They are light, strong, and well designed. Stick with these if you don't want to spend any money.
on
Originally posted by Z33@TOR
just for track use...
what size and bolt pattern of 17's should i get?
will oem 17's fit over the brembos?
on
Kosei K1s do not come in a fitment that will fit a Z without the use of spacers, and even then they would look weird, as the widest width they come in in 17s is 7.5".
Enkei Bortex MIIs would work and wouldn't break the bank too badly. Pretty lightweight for the price.
on
Originally posted by Jewelz350
Stock 17" OEM wheels fit fine over the Brembos. No spacers needed. This is what I run for autoX and road courses.
on
It affects the ride height due to the different diameter but that is minimal at best. I bought the wheels with the OEM tires (which lasted 1/2 a season with 2 drivers. Race tires next year). I have no abnormal wear from the suspension--mine is all caused by my driving!!! LOL
FYI, technically, going from the 18" to the 17" takes you out of the stock class since the 17" was not standard on my model. However, no one at a local event has ever protested it. I'd hate to run BSP just because of the wheel.
Good luck.
Good luck.
08-06-2021 06:19 AM
04-04-2016 07:52 AM
