Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > 350Z Tech Area > Engine & Drivetrain > NA Builds
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 10-03-2008, 09:09 PM   #1
1cockyZ
Points: 3,325, Level: 35
Points: 3,325, Level: 35 Points: 3,325, Level: 35 Points: 3,325, Level: 35
Today's Activity: 0.2%
Today's Activity: 0.2% Today's Activity: 0.2% Today's Activity: 0.2%
Default non revup, revup, HR rod bolt sizes and pics
I was wondering instead of buying expensive arp rod bolts to put in my nonrevup rods that will fail long before the arp bolts I would look into the revup and HR bolts. So for $6 at my local nissan dealer I found out that I can use revup bolts in my nonrevup at $34.80 for all 12. I figured this information might benefit someone. For any nonrevup owner doing cams and higher rev limit, a set of rod bolts and valve springs might be a good idea. The lines I drew and the bolts placement are a little askew but the nonrevup and revup bolts measured with calipers were equal.
1cockyZ is offline   Reply With Quote
Old 10-04-2008, 08:42 AM   #2
OCG35
yep. I did the same thing... and (stronger) rev-up oil pump
OCG35 is offline   Reply With Quote
Old 10-06-2008, 01:58 PM   #3
aggietsi
aggietsi's Avatar
Points: 3,097, Level: 34
Points: 3,097, Level: 34 Points: 3,097, Level: 34 Points: 3,097, Level: 34
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Send a message via AIM to aggietsi
Nice information. Good to know for someone on a budget.
__________________
Brady - Will work for Z
aggietsi is offline   Reply With Quote
Old 10-06-2008, 08:26 PM   #4
1cockyZ
I would like to know if the rev up valve springs fit and what the specs are. Being it would be about $130 for a set.
Old 10-07-2008, 08:08 PM   #5
KRRZ350
KRRZ350's Avatar
I had started a similiar thread on the maxima boards awhile ago, here are my pics plus some quotes:
From left to right: Standard VQ35DE, ARP, Rev-Up model
I can already see this starting a huge argument, so let me just state FTR..........
I am NOT saying that Rev-up rod bolts are = to ARP, in fact I'm not even coming close to saying that.
I am merely posting side-by-side comparison pics since I had the opportunity to do so, allthough I will say this: With the rev-ups increased rev-limit, and the fact that these bolts are only $30 vs $180, this might be a cheaper alternative for those that want to rev out to 7200 safely.
Quote:
Originally Posted by nismology View Post
And since the standard bolts are good to 7100 RPM, would it really be worthwhile to go through the trouble for a 100 RPM improvement?
:wavey:
Very good point, but if the stock bolts are good for 500+ over stock limit, don't you think the rev-ups are good much past their stock limiter as well? I merely said 7200 to hold myself of any liability.
The safe limit is 7100 according to independent testing by Technosquare. They ran a non-revup VQ35 continuously at 7200 RPM and had rod bolt failure after 15 minutes. This does not mimic real-world conditions, but 7200 is too close to the operational limit IMO. So I would settle for a 7100 RPM rev-cut if I had stock rod bolts.
Original Thread on Maxima.org
__________________
'95 maxima, 306wwhp @ 10psi & off the bottle '95 tsi: sit down, hold on, and stfu
KRRZ350 is offline   Reply With Quote
Old 10-07-2008, 08:11 PM   #6
KRRZ350
KRRZ350's Avatar
Quote:
Depending on cams, you would probably want to use HR springs, plus an extra set of shims, the HR springs are the same size.
__________________
My350Z
350 Z
Paid Advertisement
Tags
350z, arp, bolt, bolts, dimensions, failures, hr, nonrevup, oil, pump, revup, rod, spec, torque, vq35de
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
