You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Ok quick question? i have a 05 rev-up motor with dual over head cams. i want to build the valve train buy throwing the cosworth Rev-up ZK2 cams in there but im lost with the springs and retainers is my only option the cosworth ultra high RPM dual valve spring and retainer set or can i run with something cheaper like the brian crower valve kit.- thanks Shelby
Your cheapest option is to use the JWT springs, they have a cam with similar
specs & the same base circle. 10.5mm lift does not require duel springs.
