Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > 350Z Tech Area > Engine & Drivetrain > NA Builds
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 04-13-2009, 09:01 PM   #1
krivera6950
Points: 1,585, Level: 22
Points: 1,585, Level: 22 Points: 1,585, Level: 22 Points: 1,585, Level: 22
Today's Activity: 1.4%
Today's Activity: 1.4% Today's Activity: 1.4% Today's Activity: 1.4%
Default Cams
hey wats up guys. ive been doin some research and om considering doing cams to my car. i have an 05 de and want the car to make power past 6200 rpm. ive read on the different cams and there lift and duration but wanna know what cam would be good to use for increased topend and wouldnt affect my drivability. i want to keep the oem valvetrain aswell
krivera6950 is offline   Reply With Quote
Old 04-13-2009, 10:21 PM   #2
jmccarty
Points: 1,006, Level: 17
Points: 1,006, Level: 17 Points: 1,006, Level: 17 Points: 1,006, Level: 17
Today's Activity: 0.8%
Today's Activity: 0.8% Today's Activity: 0.8% Today's Activity: 0.8%
I'm told by an experienced other from the board that the stock valve springs can be used well with the Cosworth oversized valves and heads I have so aside from some risk of valve float, you should be able to keep your heads as is. I would get a bit of work done on the heads though if it were mine.
jmccarty is offline   Reply With Quote
Old 04-14-2009, 09:07 AM   #3
krivera6950
Are there any cams that i can use with the stock valves that can give me what i need out of my car without havin to replace everything. Im no looking for a cam from hell just one that will help make power pass the 6200rpm point
Old 04-14-2009, 12:21 PM   #4
Z1 Performance
MY350Z.COM Sponsor
Z1 Performance's Avatar
Points: 16,411, Level: 82
Points: 16,411, Level: 82 Points: 16,411, Level: 82 Points: 16,411, Level: 82
Today's Activity: 36.9%
Today's Activity: 36.9% Today's Activity: 36.9% Today's Activity: 36.9%
Send a message via AIM to Z1 Performance
not really, no
__________________
Adam Z1 Performance www.z1auto.com 631.863.3820 AIM:z1auto www.cornerbalance.wordpress.com
320WHP Project Z33 - All Motor - Click!
Z1 Performance is offline   Reply With Quote
Old 04-14-2009, 06:10 PM   #5
jmccarty
As Z1 said!
Old 05-05-2009, 09:51 AM   #6
ThreeFiveZero Z
Speed Racer
ThreeFiveZero Z's Avatar
obzezzed350
Points: 3,300, Level: 35
Points: 3,300, Level: 35 Points: 3,300, Level: 35 Points: 3,300, Level: 35
Today's Activity: 2.6%
Today's Activity: 2.6% Today's Activity: 2.6% Today's Activity: 2.6%
Its not worth labor cost if you arent going to do the entire valvetrain, imo.
__________________
2005 35th Anniversary Z Racecar // 13:1 NA Build // Powered by E85 // Built by Japtrix/ProsTuning // 2010 & 2011 NASA Florida PTA Champion
Follow the build here!
ThreeFiveZero Z is offline   Reply With Quote
Old 05-05-2009, 05:08 PM   #7
03threefiftyz
Moderator
350Z, OT, Market, Tech, Motorsports, & Mid-A
03threefiftyz's Avatar
Points: 3,899, Level: 39
Points: 3,899, Level: 39 Points: 3,899, Level: 39 Points: 3,899, Level: 39
Today's Activity: 68.5%
Today's Activity: 68.5% Today's Activity: 68.5% Today's Activity: 68.5%
Quote:
Couldn't agree more.
__________________
"Racing makes Heroin addiction look like a vague wish for something salty." -- Peter Egan
03threefiftyz is offline   Reply With Quote
Old 05-05-2009, 05:53 PM   #8
1cockyZ
Points: 3,325, Level: 35
Points: 3,325, Level: 35 Points: 3,325, Level: 35 Points: 3,325, Level: 35
Today's Activity: 0.2%
Today's Activity: 0.2% Today's Activity: 0.2% Today's Activity: 0.2%
It was painful getting through all the typos, the answer is listed on almost every cams description whether or not you can run stock valve springs. Making power over 6200 is not just the cam.
1cockyZ is offline   Reply With Quote
Old 05-17-2009, 02:34 PM   #9
dkuvila
sorry but. what does imo mean?
dkuvila is offline   Reply With Quote
Old 05-17-2009, 02:38 PM   #10
mthreat
mthreat's Avatar
Points: 2,749, Level: 31
Points: 2,749, Level: 31 Points: 2,749, Level: 31 Points: 2,749, Level: 31
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Send a message via AIM to mthreat
Quote:
imo = "in my opinion" in this context
http://en.wikipedia.org/wiki/IMO
mthreat is offline   Reply With Quote
Old 05-17-2009, 10:40 PM   #11
copec
Points: 2,272, Level: 28
Points: 2,272, Level: 28 Points: 2,272, Level: 28 Points: 2,272, Level: 28
It basically takes re-engineering the whole engine to target significant power increase >6200rpms, however pretty decent increases can be had in the stock powerband with some mild cams. For instance I believe the JWT cams can be used with even the stock springs within stock redline limits and the gains they quote on their site of 13whp seam pretty consistent with what else I've seen. I don't think the $1200 is worth 13whp though. I would rather use it towards more aggressive cams with a more significant build--I think most people probably would.
copec is offline   Reply With Quote
Old 05-19-2009, 02:02 PM   #12
rocks
Points: 2,744, Level: 31
Points: 2,744, Level: 31 Points: 2,744, Level: 31 Points: 2,744, Level: 31
Today's Activity: 1.2%
Today's Activity: 1.2% Today's Activity: 1.2% Today's Activity: 1.2%
Um you do not have to use aftermarket valves. I have jwt cams with stock valves. I do have jwt springs. You can get large cams from jwt, they are not listed on the website. You do have to call and order them. I was told this by jim wolf. They make custom big cams for racers. I would use brian crower springs and titanium retainers with jwt cams. My engine makes power all the way up to 7k rpms with jwt s7 cams. The powerband on my engine is 4k rpms to 7k rpms at the fuel cutoff. I need to up the limiter too 8500 and shift around 8k
http://www.briancrower.com/makes/nissan/vq35de.shtml
__________________
9:1 jwt s7 cams -Uprev tuning software. Shift at 8000 rpms
rocks is offline   Reply With Quote
Old 05-20-2009, 10:21 AM   #13
KA24DE
Points: 1,501, Level: 22
Points: 1,501, Level: 22 Points: 1,501, Level: 22 Points: 1,501, Level: 22
Today's Activity: 0.4%
Today's Activity: 0.4% Today's Activity: 0.4% Today's Activity: 0.4%
Quote:
As you've seen personally (and what I have said for years) the intake manifold is another key area.
I can't wait to see what you do next.
KA24DE is offline   Reply With Quote
Old 05-21-2009, 09:21 AM   #14
Ronin82
Points: 1,468, Level: 21
Points: 1,468, Level: 21 Points: 1,468, Level: 21 Points: 1,468, Level: 21
Today's Activity: 1.1%
Today's Activity: 1.1% Today's Activity: 1.1% Today's Activity: 1.1%
I have a question while we're talking about cams here,
A Procharger set up WILL happenbefore the end of the year, so what kinda cam profile/valve train set up should I look for now to install with my NA set up that would be compatible/beneficial with the S/C set up to come???
....for my 04 de
-borla headers/AAM hi flows/Borla TDE/ MD 5/16th plenum spacer/ osirus uprev by Dave at Function Tuned
Ronin82 is offline   Reply With Quote
Old 05-21-2009, 05:01 PM   #15
Z1 Performance
MY350Z.COM Sponsor
something without much overlap - Tomei 264's would be my personal choice
and I'd toss those headers to the curb, they ain't doing a thing for you (except making some noise)
__________________
Old 05-21-2009, 06:16 PM   #16
03threefiftyz
Moderator
+1, I haven't seen anyone who gained anything with borla headers. Most I have seen lost power.
__________________
Old 05-21-2009, 08:44 PM   #17
Ronin82
Quote:
for the record, I did lose power according to a dyno test at first.
The only way I figured to remedy this problem at first was to get a tune done. I ask around on who'd be the best guy for it and was referred to Dave at Functioned tuned. The out put after the tune feels really good and its not in my head cause of the sound(which is actually really nice IMO)
But to go experimenting with new headers with installation I dont think will be worth the product and labor. Plus until I climb into another N/A Z with a different exhaust manifold set up to show me, I dont think it will be worth labor/product. I'd go back and try a different set up if I could go back in time though.
I dont how much it will matter if im FI with a Procharger and valvetrain upgrade. But I always do respect everyones input here. this being my first Nissan, its definitely not like my fiance's EVO IX, or my old CRX H22a.
My350Z
350 Z
Paid Advertisement
Tags
cams, jim, s7, wolf
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
