Jenvey Individual Throttle Body Intake for VQ35DE
Old 08-10-2012, 07:57 AM
Kwame
Kwame's Avatar
What parts were modified on your kit that would be applicable when fitting a standard kit from Jenvey on a 350z?
If my question is unclear, I'm basically asking what do you have extra in your kit or done to your kit that I should considering paying you for a used kit that costs only a couple hundred dollars less then a brand new kit from Jenvey (I have recently priced out a new kit from Jenvey with the curved horns sans the air filters and its not very far off from what your asking)?
Kwame is offline
Old 08-10-2012, 09:47 AM
kgkeen101
kgkeen101's Avatar
Perfect question, the kit I have was tapped to connect right now. The vacuum block/surge tank was welded and created for the kit. Also, the vacuum lines that were tapped were also part of getting the kit up and ready. It totaled in hours of additional labor. The kit I was sent was nowhere near ready to just get up and go. The ITB I have is all set, has been used and I will send you the vacuum surge tank with it. Right now the kit is almost 3000 from Jenvey. I think with all the work I did to get it working it is worth the price I am selling it for.
kgkeen101 is offline
Old 08-10-2012, 09:50 AM
kgkeen101
kgkeen101's Avatar
Pictures of the vacuum surge tank and connectors all welded and built for the Jenvey ITB setup. You will need this.
Old 08-12-2012, 09:27 AM
kgkeen101
kgkeen101's Avatar
Weekend bump for NA driven enthusiast
Old 08-13-2012, 10:10 PM
Kwame
Kwame's Avatar
Thanks for the clarification.
Kwame is offline
Old 08-14-2012, 10:37 AM
kgkeen101
kgkeen101's Avatar
I will also be sending the TPS sensor for the kit as well. I'll get a picture to add to it.
Old 08-19-2012, 07:07 PM
kgkeen101
kgkeen101's Avatar
Bump for ITBs for grabs! Also have ProEFI Pro48 ECU for sale, JWT C9 Cams, Wiseco Pistons 11.1 96MM, Eagle Rods! PM if you need
Old 09-01-2012, 05:00 PM
kgkeen101
kgkeen101's Avatar
Bump for ITB, NA enthusiast wanted or turbo build but will require air box built, can direct you to who will build it for you for a quote if you want!
Old 09-10-2012, 03:52 PM
kgkeen101
kgkeen101's Avatar
Lot of PMs responded to, still looking for the serious NA enthusiast for the ITBs
This is the same kit that Sash is using FYI, 372WHP. He accomplished this on this same kit
http://www.sg-motorsport.com/?p=1088
Old 09-15-2012, 01:02 AM
kpturbo
kpturbo's Avatar
SOLD to me And this is where the ITB is going to have a happy future.
Toyota starlet (KP61)
Looking forward getting the Jenvey
kpturbo is offline
Old 09-15-2012, 01:08 PM
3hree5ive0ero
Retired Admin
3hree5ive0ero's Avatar
^ You should create a thread here about your build.
3hree5ive0ero is offline
Old 09-16-2012, 09:07 AM
0jiggy0
0jiggy0's Avatar
Wow, in for future win
0jiggy0 is offline
Old 11-12-2014, 05:34 AM
KingBaby
Hardest Setting
KingBaby's Avatar
bump
because I missed the awesome the first time
KingBaby is offline
apex locator
07-23-2021 02:27 AM
11-09-2020 10:27 AM
04-04-2016 07:52 AM
Quick Reply: Jenvey Individual Throttle Body Intake for VQ35DE
