Any help would be AWESOME - MY350Z.COM Forums
Thread Tools Search this Thread
Old 03-20-2017, 10:49 AM   #1
con_man16
Default Any help would be AWESOME
I hope all is well. I recently purchased a 2004 Nissan 350z roadster w/105xxx miles bone stock. The seller said that the car wont rev, so i figured it would be an easy fix. I've replaced almost every sensor, no change. I dug into the wiring harness and found a few bad connections, spliced wires, and pushed in pins at the ecu connector. I ordered a new harness, installed the harness, and now it cranks but wont start. Ive done the learning procedures numerous times, it has a strong battery, not sure where to go from here. The red light for the security system does not stay on while attempting to start so i dont think its the NATS. Any advice would be greatly appreciated.
con_man16 is offline   Reply With Quote
Old 03-20-2017, 01:10 PM   #2
zakmartin
Orange MoodRing
zakmartin's Avatar
Take it to a Nissan dealership, tell them it's broke and realize you just got swindled by someone who sold you his problem.
zakmartin is online now   Reply With Quote
Old 03-20-2017, 01:11 PM   #3
travlee
Master
travlee's Avatar
But that costs money and makes too much sense
travlee is online now   Reply With Quote
Old 03-20-2017, 01:17 PM   #4
350Z/370Z Tech Moderator
MicVelo's Avatar
Quote:
You pulled codes, I presume?
MicVelo is offline   Reply With Quote
Old 03-20-2017, 01:18 PM   #5
travlee
Master
travlee's Avatar
Suuuuuuuuuuuuurvey saaaaaaaaaaaaaaaaays
no
Old 03-20-2017, 01:20 PM   #6
dkmura
General & DIY Moderator
dkmura's Avatar
Quote:
^^THIS and realize your Z33 needs a CONSULT III and an experienced tech to get it back running right. Less money and headaches than throwing parts and expletives at it.
dkmura is offline   Reply With Quote
Old 03-20-2017, 01:24 PM   #7
con_man16
OK so apparently while i was in the garage for 30 mins i got a lot of replies. I got it to start but it wont rev. I dont want to take it to the stealership cause the closest one is about an hour away. I'm gonna pull the codes again and see whats on there. Only code that was on it last time was the one for the pcv valve or something like that. My M35 has that same code and it runs fine. So yeah.
Old 03-20-2017, 01:49 PM   #8
con_man16
P0011 "A" Camshaft position-timing over-advanced or system performance
P0447 Evaporative emission system vent control circuit open
P0021 "A" Camshaft position-timing over-advanced or system performance
Old 03-20-2017, 01:51 PM   #9
travlee
Master
travlee's Avatar
Replace sensors with oem....go from there
Old 03-20-2017, 02:01 PM   #10
con_man16
ima swap the ones from the M and i will check back.
Old 03-20-2017, 02:10 PM   #11
travlee
Master
travlee's Avatar
Good plan
Old 03-20-2017, 03:05 PM   #12
con_man16
Revs a little, very rough idle. i have to press the pedal all the way to the floor. Honestly sounds like the timing is off.The only way I know to correct that is to get the ecu flashed........
Old 03-20-2017, 03:26 PM   #13
dcains
dcains's Avatar
Sounds like the seller was the con man.
dcains is offline   Reply With Quote
Old 03-20-2017, 03:33 PM   #14
con_man16
LMAO yeah ikr.
Old 03-20-2017, 03:34 PM   #15
dcains
dcains's Avatar
Couldn't help myself.
Old 03-26-2017, 03:15 PM   #16
samsniss350z
samsniss350z's Avatar
Welcome and let us know how you get on.
samsniss350z is offline   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright 2002 - 2008, MY350Z.COM All Rights Reserved.
