oil to use for a 350z nismo 2008 engine vqhr has twin turbo approximately 700 h
on
Hello my friends I want to ask your advice what oil to use for a 350z nismo 2008 engine vqhr has twin turbo approximately 700 hp with injectors rc 1200cc me is wearing the connecting rod bearing lack of lubrication and then I do not know that oil would be the best if you can me Give a lot of advice
You'll get an opinion from everyone...
look into Driven Racing Oils - I believe the DT40 would fit your application.
I'm paraphrasing bealljk here but you'll find one driver who prefers Pirelli, another prefers Toyo, yet another prefers Yokohama. This applies to oil too. Have you built this yourself or bought it built in which case ask the previous owner what he was running.
Welcome to the forum.
OP^
and I should say that if you can't swing a $12/quart of oil from a specialty shop than look into a quality synthetic from a trusted manufacture.
no engine oil is going to stop an engine failing due to clogged lines, an abused engine or a sh!tty filter...
