- HR where to pick up TACH(RPM) signal ??
- -== Is this normal?? ==-
- Nitrous VS o2 codes?
- Need help with Dynotune Solenoids, and bottle mounting.
- Install and Dyno Video on a Zex VQ35HR Nitrous Kit
- Bottle open or Closed?
- Your dream non-direct port nitrous kit?
- Zex Kit Explosion
- Question about micro switch and arm switch in Dynotune kit.
- Anyone running Nitrous with Vortech?
- 343hp 341 lb/tq VQ35HR
- Nitrous Cost
- Nitrous Amazing Dyno Results!
- Traction Question
- Cars Shuts off
- Couple dumb questions.. thanks in advance
- Freshly Painted Bottle...No Tools Bottle Removal
- Same plugs in Rev-Up as DE?
- Wideband Controller(Innovate)
- 200 Shot on HR..?
- I need help asap w/ zex install!!!
- New to Nitrous and need help
- Wideband for 03's
- Colder Plugs/ Not spraying
- My N20 Progress.
- Jet Sizes and A/F Comparison
- nos sniper kit for 350z great for prize
- Cubby Gauges
- uprev tune on nitrous?
- Bad bottle?
- Lets get it!
- good window switch??
- Dynotune Wet Kit Nitrous Install on HR
- For everyone who wants to FINALLY KNOW!!!
- BG44k and Spray?
- zex kit with all the bells and whistles
- Soon to be another Bottle Fed Z !!
- 07 HR nitrous installed!!
- Nitrous + Cams?
- VQ35HR 2007 350z Zex Nitrous Kit Install Started
- HR One Step Colder Plugs
- Add me to the list!
- Proper Air Fuel Ratio On Nitrous?
- DynoTune Nitrous Install Problems?!>!
- Nitrous Spark Plugs
- Anyone Know the Colder plug Part number?
- IS A NOS SNiPER KIT OK FOR A 350Z
- Spray with meth
- nitrous question
- Nitrous Install
- SERIOUSLY thinking about comming the the darkside
- NITROUS REMOVAL HELP
- dyno numbers and a couple ??'s
- Kit buying advice?
- How much are you spraying on your stock engine?
- NOS upgrade, need help
- Finished nitrous install on my 07' Nismo Z
- Nitrous with HFC's or resonated test pipes?
- timed 1/8th mile
- record on spray
- Dynotune window switch issues
- Headed to the dyno today . . .
- ZEX specail
- Nitrous ReInstall for stealth
- High Mileage vs Nitrous
- Questions on Nitrous for my 07' Z
- nitrous
- Switch Panel/Map Switch Added Install Pics
- nitrous and methanol injection
- NOS Installer in SAC or BAY?
- Dynotune Air/Fuel Ratio Lean Shut-Down Switch Review
- nitrous vs. stock internals
- DIY for a nitrous install on a 350Z?
- Pros and Cons
- Help!! 75 shot,+ na mods 14.2 E.T. !!!
- Watch the vid and make the call
- shooting a HR
- Nitrous Leak
- zex module location....
- Different brands, different Nozzles?
- hows your ride
- nitrous at high altitude
- pulling timing?
- Engine Harness Cover / Nitrous ?
- TPS wire location?
- Pics of Nitrous Mount Not Stealth
- I guess I'll come out and play too..
- Yet ANOTHER stealth Nitrous Install N0 56k
- New Nitrous Setup!
- Check out my nitrous panel and a ?
- bottle warmer problems
- nx remote bottle opener issues
- best window switch??
- my dyno numbers
- 75 shot no tune
- Nitrous Setup
- The Ultimate Nitrous set-up
- NOS with vortech and water/meth
- Leak!! Help
- get yo purg on
