- installation instructions for bottle warmer
- question to the n20 gods
- quick ? 150 shot
- fuel line adapter
- installation instructions for zex wet
- Finally took pics of my stealth nitrous system
- my 03 base runnin a 75 shot at the track
- spark plugs?
- how long?
- What RPM range is your window switch? 1st gear lockout? Yes or No?
- nitrous and warrenties
- nitrous and cams?
- spark plug gap
- can i spray??
- what do you think?
- Sprayed and Boosted?
- back from the dyno!!!
- plugs or no plugs???
- zex kit and window switch
- Dynotune Window Switch
- Is Engine Management a must?
- question
- VQ35HR specific Zex Nitrous kit just arrived
- Install Question
- nitrous with race fuel tune
- Is this a Good NOS Kit??
- 150 shot?
- Fuel Pump
- Newbie question
- How much you spraying?
- 350z Dry Kit???
- Jet Zizes.... Question
- What are the nitrous buffs running???
- ZEX TPS Trigger
- Best way to install Fuel Pressure Gauge?
- Gas Octane
- What you Spraying?
- how long does the bottle last?
- nitrous install pics
- new Zex install pics
- Nitrous in the Z?
- Throwing flames
- How often do you change spark plugs?
- Dynotune a/f shut down + rpm/ window switch?
- Newbie question
- Anybody using the NX Octane series gauges?
- NOS newbie question
- nitrous tune and install???
- Got Zex kit for cheap
- Nitrous Xpress Carbon Fiber bottle
- Here we go!
- bottle mounting question(s) on Z
- Bottle Fed HR!!!
- zex bottle warmer question
- OK What am I running??
- WW conversion to Meth... em I stupid?
- How do i take this off without breaking it?
- Nitrous n00b needs HELP! (Please Read)
- A quick warning........
- Quick Question
- 07 Nitrous
- nitrous in a 350Z
- spark plugs for 2007 +
- Malfunctioning Solenoid
- Temporary Satisfaction, Nitrous
- Questions about install...
- Direct port fittings?
- were should i purge
- Water/Meth Injection on Spray
- What needs to be done
- Greddy Emanage for nitrous?
- need help plz
- NItrous Direct Port
- utec version 2.8 spare soleoid and nitrous?
- sweet idea for N02
- Aftermarket Nitrous Control Module
- Nitrous and Meth...At The Same Time!!
- Install Idea ????
- Hitting The Rev Limiter
- Nitrous Kit Finished but... Help Please
- What do you guys think about this??
- Damage Of A 75 Shot
- Which Nitrous Kit To Get? Need Help!!
- rpm windwow switch ebay??
- Nitrous and the Tiptronic
- My first ever vid
- Newwwwwwwwwwwwwbie!
- Problems!
- check engine light on after zex set up
- New Nitrous Set Up
- G35 switches in ashtray
- one step colder plugs???
- Spray guys
- need help asap!!! Zs broken
- help finding the tps wire to tap in
- Will the eManage will with Nitrous?
- do you delay nitrous for .03 sec?
- 150 Shot on stock block
- Is a 75 shot safe?
- BLACK SERIES CONTROLLER P Version
