- Leaking Zex Nitrous Solenoid
- From a NX 75 shot to a 150 shot!
- New Nitrous Build
- NOS Progressive Controller TPS Issues
- Nitrous setup
- IS350 on Nitrous Crash Vid
- which RPM window switch to get
- osiris/utec stack
- nitrous pressure gauge and nano nitrous system
- Nozzle shootout
- direct port idea
- nitrous newbie
- Vendors or Members .. NX Nitrous Question ..
- putting together nitrous setup need some advice
- Dyno Tunes Window Switch?
- Nitrous Solenoid
- Where do I install the Nitrous Nozzle?
- Clean Hidden Install
- Running Lean With a 30 Fuel Jet
- Runnin Nitrous On Stock Motor
- Pricing on a Zex nitrous kit. What is a good deal?
- NEX 4-6 Cylinder EFI Wet Nitrous System
- hr nitrous spark plugs?
- Help!!! Utec as nitrous window switch!!!
- problem wiring a window switch for nitrous
- My Zexxy Nitrous with Microedge install
- new to nitrous
- Best kit for Utec
- not new to nitrous or performance just the vq35
- Nitrous trap speeds
- 125 shot jet size HR?
- nitrous question
- ? for those with ZEX
- Nitrous and Engine Wear
- Bottle Valve Question
- My Dynotune nitrous install
- Hidden Nitrous
- nitrous.vs.head bolts
- running dry safe?
- new parts
- Leaving armed with window switch and WOT switch
- Fuel Adapter question
- WIDE-B AFR.. where to tap o2 sensor
- Looking to buy a Nitrous Oxide setup ADVICE APPRECIATED
- upgrade injectors for NOs?
- Dynotune bottle warmer users
- Steering Wheel Controls for Nitrous
- Nitrous vs SC
- Zex Nitrous Jet Sizes
- Methanol as fuel with Nitrous
- My "Clean" Nitrous Install
- Nitrous install on 05 FX35 AWD questions
- Nitrous Noob Questions
- Nitrous Express Fuel Accumulator
- 6 Cyl Direct Port
- Fuel Cleaner in tank with nitrous issues?
- Blown up your Z with nitrous?! Tell us about it
- Wideband A/F from dynotune
- ZEX kit Nitrous setup help
- Nitrous kit
- Maximum shot of a zex 82220 kit
- SES w/ P1564 and P2135 on ZEX: found cure
- 75 Zex wet...pulling timing question?>
- Found oil pool in cyl. 6 upon install
- Nitrous degradation
- ZEX NOS not working for 08 350Z, help please
- NOS system
- need some advice for nitrous setup
- does anybody know size of the fuel jet i need...
- Issues Running Tach to Window Switch
- How to cool a nitrous bottle?
- 06 Base Nitrous in the works.
- buiding a stock vqde with nitrous
- I have an automatic, please school me on the limits of nitrous.
- Direct port spray bars
- 2006 350z some mods and some spray
- Any good hiding spot Ideas for the bottle?
- Progressive Shots -- how do they work? And, nitrous plates?
- Just sprayed on the dyno. Pig rich as can be.
- Nitrous carnage
- Nitrous questions
- Spark plugs for a 100 shot?
- The Juice is loose
- Zex Nitrous on DE
- Tuning a Dry Shot
- Be honest, how many of you guys actually run this on your street cars?
- Nitrous - Melted Spark plugs, WTF
- Fuel tapping
- Nitrous discoloration.
- 25/50/75 shot on stock Rev-up
- help! 2006 Z looking to spray...
- to those who have used a utec to pull timing
- Ignition retard
- anybody got any coupon codes for sparkplugs.com
- spraying in 5th and 6th gear
- 100 shot or less will these spark plugs work?
- will this a/f lean shut down switch work with z
- Nitrous Vs. Torque Converter
- Need some gauge pods
- utec help
