- 03 z with supercharger, wondering what oil you guys use?
- Crankshaft questions
- Can CAMP2 read boost from EMS?
- Call all current and pervious owners of IPP shortblocks....blow by issues?
- cruise control helppppp
- Could use some direction: loss of boost | ominous ticking noise
- Anyone have experience with Cosworth 8.8:1 built blocks?
- coolant overflow tank cap
- I'm the proud Father of...
- Check out my new Z!
- Cipher
- AAM?
- Any known problems with greddy oil pans??
- wideband bung welding
- Does my vortech need a rebuild?
- Help,help,help!!!!
- Long block or just pistons/rods???
- JWT C9 Cams
- Greddy oil block & turbo oil feeds?
- Cass007.... ver 5.0
- Jtran Studios Presents turbo kits (fabrication thread)
- Revups with ProEFI 128?
- My vortech build
- haltech help
- 2 steps colder then stock copper plugs
- 2003 vortech sparkplug recommendations.
- FI... Supercharger or Turbo?
- How do i remove this welded oil drain and seal the oil pan??
- My 350z TT Build with Pics
- Vortech v3 Project from over the pond...
- 400hp goal
- How hot are you running
- My 928 Motorsport Vortech impeller dyno
- Need some input on some tight fitting powerlab pipings
- Controlling a methanol kit with the haltech
- vortech bpv issues
- Injected Performance has a something for folks with Nismo rear diff covers!
- UK Tuner
- aem ems help
- ** Boosted Performance ST Kit.. Results & Review **
- Powerlab Dumptube Weld Crack
- odd problem arose at the track...05 revup G
- where to rebuild vortech blower?
- How to manage a bad case of blow by ...
- Aem wideband
- Oil catch can: what size tubing?
- how to get 500whp or more out of Powerlab?
- Heat Management Tactics?
- ? about the oil feed line for a greddy turbo.
- Powerlab?
- Haltech Platinum and Platinum Pro, any difference?
- started my greddy twin turbo install
- Say hello to my little friend
- My 928 Motorsport experience.
- My experience with Z Car Garage
- Im lost
- One thing after another, car stumbles in the 2-3 shift.
- Vortech Cog Belt Messed up Cam Wire....
- turbo set up
- V2 *IDLE coolant overheat*
- Is my exhaust too small?
- Took my Vortech G to the dyno again with new mods...yet it's still weak...
- Revup aftermarket head gaskets
- Turbo a tiptronic?
- Vortech people, how are your IAT's?
- Superchargers - Blocking vacuum line to BPV
- Curious if the HR shortblock would work with DE heads?
- More FI mid turbo projects...
- ems helppppp pleaseee
- E85 injector sizing
- Greddy Pressure sensor Orifice size.
- Anyone have a pic of a gutted oem or non-oem muffler? Is my ebay one restrictive?
- Vortech V3 leaking, but not through seals.
- Brian Crower stroker kit? and big cams??
- Blew the tranny on my Z (5AT), what are my options?
- My 350z Build
- Estimated # of hrs needed to swap heads
- Any knowledge of CURRENT mfg of Greddy WG reloc kit???
- F-con vs Haltech
- Trouble shooting help- APP/TB
- APS ST and zero Oil Pressure Reading
- Polish or powder coat Vortech pipes?
- Exhaust Manifold and Turbo Bracing
- My build: Greddy HR TT 350Z
- cheap braided lines for oil coolers! look
- 350z transmission helpppppp
- should i buy a supercharged 350z with 65000 miles?
- Explain this wire???
- Help needed - emanage tune cutting out 5000rpm!!
- Exhaust question!
- Cometic 100mm headgasket
- hks f con harness
- My Vortech Si Trim Version 2.1, Uprev Tuned
- Think this would work for a Vortech cog pulley belt?
- Homemade Vortech pulley mod.
- Tease!!!!!!
- Twinturbo with single 3" exhaust and 3" Y-Pipe?
- Powerlab 35R kit will not make 500 HP
- Where and who is this Shade Tree Mechanic????
- Looking for OVERdrive pulley.
