- New Numbers......slowly getting to what I want
- trying to pick exhaust for TT
- GReddy Turbo Timer Quick Working
- New built motor break in map??
- Shop Discussion Thread
- APS ST Install
- No boost/ Car stalling upon start up
- that noise is normal?
- GTM Performance Engineering & Forged Performance
- Evc 6 and Fcon
- Car keeps blowing coil packs??????
- What belt size for 3.12" pulley?
- GTM Performance Engineering & Forged Performance - Parting ways...!?!
- Hal’s street car sets 6speed 350Z record at 9.34, VIDEO
- Brian Crower Stage III cams, when do they start making power?
- Anyone have the HKS turbo timer???
- Vq35HR, build questions
- Looking for a 7 psi radiator cap for running Evans NPG+
- Car suddenly started running really rich yesterday..
- Carbonetics clutch revisited..
- Relocated Vacuum Sources - Overboost?
- ARC v2 catch can routing for SC
- WOW! look at the size of this S/C.
- Need Help
- Defi boost gauge calibration?
- Greddy TT kit?
- Ross's Twin Turbo build ::PIC HEAVY::
- Searched my ass off to no avail...
- Is a stiffer engine mount available for the GTM VQ35HR TT Kit?
- oem size cap on aftermarket radiator
- Possible blown head gasket? Loud pop under boost log
- Stock blocks and oil burning. Post up what you use.
- New setup: APS ST to GTM TT STG2. The build just started.
- Vortech Sq kit first impressions
- FI Guys with trans go valvebody upgrade.
- Haltech Platinum 350z Intake and Exhaust CAM timing numbers
- Wiseco Piston to Bore. Does it need more 0.0025
- Any g35 running the powerlab turbo gt35r???
- Machining Vortech Cog pulley
- Aeromotive FPR o-rings, anyone know the P#?
- ***ProEFi 128 Unit w/FlexFuel Review***
- Adaptor for fuel line quick-connect?
- Fujitsubo Legalis R Exhaust for powerlab GT35r
- Trying to put a seal in my supercharger and need advice........
- Built Automatic for FI, experiences?
- Anyone know what's up with uprev?
- I notice that no one has a set up with 5-7 PSI (350WHP) and short gears?
- Possible OBD Emissions Cheat
- New to force induction and have questions
- Anyone have pics of Greddy Tuner Kit downpipe/wastegate setup installed?
- Forced Induction.... Alittle confused?
- Vortech V3 Uprev Graphs
- Looking for: greddy tt downpipes and WG relocation/open dumps
- Going back to stock injectors/ECU with a return fuel system
- HKS Knock/Amp meter question
- Have to share this with you guys
- Custom cog belts
- ahh bummer..... what do you think about my situation..
- Vortech pipe couplers ???
- stage 1 short block from IPP!
- Pushing the Limits
- Turbonetics kit What boost controller should i run?
- HKS GT SC Help
- HKS GT SC vs. Vortech SC...which should I choose?
- Fuel economy meter inaccuracy with larger injectors
- Cryogenic Intercooler Sprayer
- ***Sound Performance Boost Activated Exhaust Cutout Results!!! VIDEO INSIDE
- t-bolt clamp sizes for vortech supercharger
- APS ST Need help wiring the scavenge pump & oil solenoid
- Vortech Oil Seal Going Bad?
- Hills garage is now an authorized REV UP dealer
- My magnafuel external fuel pump setup(thanks to Larry at SP!)
- Turbo question/ Boost ?
- few vortech revup questions
- I have traction now!!!!!
- JIC single restriction:: resonated vs non-resonated
- Need Help with Stillen SC kit! Please!!
- MREV2 and spacer question
- My HKS S/C Installation
- Water to Air intercooler - F/I benefits
- PE Twins with Nismo Exhaust?
- SuperLeggera 350z HKS SuperCharged
- Pressurized Cooling System- F/I benefits??
- JWT TT KIT FOR G35 ON A 350z?
- misfire; short list but how to diagnose?
- Smoking exhaust question when letting off throttle
- Need suggestions on an oil cooler
- Big boost?.. Was it worth it?
- Old question revisited: APS TT kit and smoke out of the exhaust at idle.
- 3rd Annual Forged Performance Airstrip Event!
- FI on a Base model ?
- need recommendation for front tires to go with R888 in back
- AC______&______TT
- Wierd Problem
- Stock injectors on AAM RFS
- GT-R turbo's in a 350z/G35?
- Timing chain assembly re-use
- Need an oil scavenge for TT application...
- Shortblock Build
- Oil change 350z TT
