View Full Version : Forced Induction
  1. That's not a turbo...
  2. cometic headgasket or HR headgasket
  3. finally.. well almost!!!
  4. Inputs on Crankcase Ventilation System (Greddy TT)
  5. HELP!! My car wont start!!
  6. Cams and the rev-up engine
  7. Aps tt + jwt c8r
  8. What could be wrong?
  9. Project Big Blue
  10. APS Oil Pan Oil Return Thread Size
  11. Some turbo (Precision) input
  12. Replacement APS TT filters
  13. Procharged Z running too rich
  14. Confusion regarding T25, T3 and T4 turbine flanges
  15. Long delivery, should i worry?
  16. So....how wants to make some serious single turbo power
  17. How many miles on engine before TT is not good idea?
  18. FINALLY installed PAR upgraded 3rd+4th gear in 6MT
  19. HKS A/F Knock AMP reads nothing and car sputters
  20. APS TT Questions
  21. New 4.2L turbo 350z some???'s
  22. Need a little help from my FI friends (EBC and Osiris)
  23. Is it worth ceramic coating or molly coating the pistons for an F.I. build?
  24. Which guages are essential?
  25. Found metal in oil
  26. 20g potential
  27. Limit of standard arp headstuds
  28. stillen sc help
  29. Help me identify the loud ticking noises I heard today
  30. Return Fuel System
  31. will greddy turbo kit fit right hand drive?
  32. Greddy Turbo Kit on RHD 350Z question
  33. Why does my turbo car sound like a diesel?
  34. Boost. It’s like a Drug (Crack)
  35. Scam or not
  36. Have any FI'ers had any kind of throttle response issues?
  37. Critique my build...
  38. Finally: GTM Stage 5 + E-85 + G35 = Awesome
  39. CEL Codes
  40. Anyone Install RC injectors on the Non-Rev?
  41. HKS SC + 85mm Pulley = Out of Breath?
  42. questions with my twin turbo build
  43. Builders,tuners,moderators please help!
  44. Help me select my piston/Rod combo!!!
  45. Just got a Vortech tune ran good for only a few days.
  46. So What Do Cams Get You????
  47. F/I on Budget
  48. Best clutch/flywheel setup for f.i. 450 h.p. Range?
  49. methanal percentage question
  50. Electrical issues after TT
  51. What do open dumps do exactly when boosting?
  52. osiris uprev map question
  53. The Official Shop Rating Thread!!
  54. Has anyone ever recirculated their vortech bpv?
  55. Spark plug... thought it was easy
  56. 400whp
  57. what will I need to do to get a non-rev up vortech kit to work on a rev-up
  58. Future turbo question
  59. How long might the motor last?
  60. stock or lightened crank pulley for F.I. ??
  61. Light knock when rich at 14psi, maybe spark blow out,
  62. Oil Filter Block Adapters
  63. Cosworth intake plenum + injectors
  64. citymunky's GReddy build.
  65. 2 step launch control
  66. Finally got my boost!
  67. if I wanna keep my nismo exhaust, can i use T?
  68. aps Twin G35 oily plug and misfiring..
  69. Questions About Turbo
  70. Finally the build has started. Overview and some Questions
  71. Built motor @ 17psi misfire
  72. Quick question about Vortech
  73. Hks gt s/c volume
  74. Almost bit the dust! Pics inside
  75. Another Powerlabs DIY and picture diary
  76. It sold!!! Congrats Alex (agallardo) enjoy ur new Z!!!
  77. Comment Pro/Con on the Vortech S/C
  78. U-Tec question help!!
  79. Oil Leak in 5th cylinder
  80. Actuator springs and PE TT kit....
  81. GTM Oil cooler install
  82. Anyone know what TT kit this is?
  83. ATI blower cog bolt
  84. pass rear tire sticks out much further then drivers side
  85. Big Koyo Overheating??
  86. Engine build opinions...
  87. Fuel is literally being dumped from engine bay area.
  88. does vortech rev-up work on non rev-up engine??
  89. Life Expentancy for FI Z's
  90. Got P0024
  91. Do i have to retune???
  92. Short block assembly... engine builders please help..
  93. What is everyone running FI getting for EGT's??
  94. replaced cam sensor car wont start
  95. HKS GT supercharger quick question
  96. Installed my Cosworth intake manifold
  97. Mounting spot for Meth on 350zR
  98. Injectors installed, new spark plugs. Bogs when driving for a little while.
  99. water in engine quick questions
  100. Greddy oil pan or AAM spacer
