- Retaining STS kit w/ LS-1 swap
- Finally ran my car at the track last night.....
- what happened to ultimate performance?
- Has anyone installed an HKS Turbo "Setup Kit" on a Z or a G? I need help!
- Quick question about oil in charge piping
- AFR's
- Camp 2 (Eco mode)
- Yet another Powerlab kit in progress.
- Rear Turbo Kit
- HELP: Car smells funny and runs hotter than usual but doesn't over heat
- DIY.. APS TT Build on a RHD UK car.....
- Quick Question: what is the exact length of a VQ?
- Valve buildup issue
- please check this map for vortech 3.33 pulley
- Haltech boost controler need help
- Idle jump
- Oil Change
- Injector Duty Cycle wire tap with F Con V Pro
- Pauter rods w/ARP2000 fastener?
- what do you think I need for making high hp?
- apexi turbo timer help
- Vortech ruining AC lines?
- HELP: Vortech leaning out on higher RPM revup
- Need Help Sourcing APS Product
- Hal's 6speed street car runs 9.8 @ 148mph!!!
- Start up
- Oil pressure sending unit
- RPM right after WOT run
- Upgraded injectors for untuned Utec drivable?
- GReddy Twin Turbo on 5AT?
- Navi / Fi / Fcon
- Intercooler sprayer
- Garret GT 40 turbo build
- Car won't start when hot
- 4 those who r turbo on a automatic ! I NEW HELP! TIRED of HEARING USE SEARCH!
- Installed Vortech today, with Utec, Speedo and Triple gauge not working, Please Help
- Man thats fast
- First Z owner and FI car!!! w/ pics!!!
- Problems w/ Power Enterprise Turbos
- S/C Z
- To make better the cooling sistem
- car would start up then dies out.
- The Time Has Come MADScientest is selling his car!
- Ughhh, all of a sudden got these codes. FML. Help!
- JWT 700bb Greddy Evo TT...switch to HKS Duals?
- Large Intercoolers and Crash Bars
- ARP L19 head studs tightening torque settings
- Gt4294r g35
- Vortech Superchager Issue// HIccups?
- Stock Block FI
- Recommendations for electric fans for coolers?
- Removed EVAP
- Headwork... DE vs HR flow testing
- H Beam vs I Beam
- My Build
- manual transmission fluid for FI
- Oil Catch can drain
- knock amp owners help me out
- STS turbo
- Going back to stock...
- Timrod Belt Layout with extra idler pulley
- Will oil on MAF cause a P2135 code?
- jwt flywheel with 500hp car and comp clutch stage 4 clutch?
- Snapped the fitting in the motor. Other solution for oil line? (Vortech help!)
- So how many fully built there DE motors,and didnt balanced the whole rotating assembl
- Car won't accelerate, studders from a stop in 1st gear
- F con Navigator won't show AFR
- GTM VQ35 Connecting Rod Set vs Carrillo Pro-SA
- turbo flange size, t25 vs others
- Which performance oil pan for forced induction?
- Blown Vortech, please help
- Front Undertray removed on TT
- How long are your spark plugs lasting?? BUILT TT guys
- Headers for SC'd Z
- vacuum problem w/ ATI pro charger
- Torque Plate. How thick does it need to be?
- Haltech external MAP sensor calibration
- GTM vs. AAM 3" downpipes w/open dumps
- procharger help!!!!
- Garrett GT40
- AEM Oil temp gauge question,need help please :)
- HELP - No Throttle response - TN single turbo kit
- Best Forced Induction for Daily Driver?
- Sleeved block w APS twin turbo temp?
- APS's parts
- Spark plug question ???
- Rear Mount Twin Turbo
- Emanage ultimate tune?
- Split Second Box / Vortech question
- Need advise....
- 272 Cams on VQ35DE Daily Driving?
- Supercharged to be
- We need a 3D model of a G35 Coupe
- new 03 350z STS turbo!
- VQ Drag motor build
- Anyone want to help with DIY Turbo Timer Install?
- Can i put nitrous with vortech
- Preferred MAF Sensor Location w/Turbo - Before or After Turbo?
- SFR Twin Turbo complete kit
- can i turbo my automatic 05' 350z?
